586,116 active members*
3,469 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Why I can´t 4th axis create NC code?
Results 1 to 10 of 10
    Oct 2008
    6
    Hello,
    I created the VNC file with 4th axis milling(I attached vnc file (v.9.0.6)). I have 4th axis post but I can´t generate g code with A coordinate when I used 4-axis operation. Gibbs only generates X,Y,Z g-code without A address. Does anybody know where is the wrong? It´s the post or settings. Does anybody has a right metric post? I´m sorry for my english language
    Thank you a lot for the answer
    Gibbs file with this problem:
    http://rapidshare.com/files/244461429/spiral.vnc.html
    Jan 2008
    73
    POST Problem
    You need new POST:
    http://jeffcnc.spaces.live.com/
    Oct 2008
    6
    Quote Originally Posted by jeffliu2 View Post
    I tried use post-processors from this web. I set the 4-axis machine and I used rotary pos/processors from this web. But I can't generate the rotary axis A. I don't know what is wrong. So, does anybody have the corect post for it. Please send me it
    (it would be best in metric unit and fanuc)
    Jan 2008
    73
    Re: Post-processors
    Quote Originally Posted by flashmaster View Post
    My web haven't 4-axis post-processors, I don't know what you did.
    If you want i try it for you, please email me your VNC file : [email protected]
    Thanks, JEFF
    Oct 2008
    6
    Thanks, JEFF
    Hello I sent you my problem with post to your email.
    Thank you a lot
    Apr 2012
    Jeff or Flashmaster, have you resolved the issue?
    I am having exactly the same problem, with the following setup:
    4-axis vertical mill, enabled in Gibbs document control and using a correct post (Haas [xx] RMxxxx.pst, and have tried lots of others)
    All the G-code comes out with a single A-axis positioning line at the beginning, and no live 4th-axis motion in the body of the program.
    Suggestions? Thanks!
    Jun 2003
    513
    Quote Originally Posted by CLDaniel View Post
    Assuming you actually have rotary mill toolpaths, the posts you are trying to use are not rotary mill posts, or they were incorrectly modified. If you got these posts off the web, then more likely than not, they are probably junk or have some weird modifications to them for a specific requirement at the shop they originated from. Contact your reseller for a good post.
    Apr 2012
    Our reseller has been less than responsive, which is why I'm seeking information here. CNCzone has been a great source of information in the past.
    Jun 2003
    513
    Go directly through the post department at Gibbs. All of my post modifications are done by them with zero problems.
  1. insert nc/create code
    By YubaVinnie in forum BobCad-Cam
    Last Post: 01-17-2011, 07:57 PM
  2. how to create code with inkscape
    By dertsap in forum Uncategorised CAM Discussion
    Last Post: 12-28-2010, 10:08 PM
  3. How Do I create the G-Code?
    By mrcodewiz in forum Dolphin CAD/CAM
    Last Post: 04-10-2008, 05:06 PM
  4. How do I create the g-code for this?
    By cnczoner in forum BobCad-Cam
    Last Post: 03-18-2008, 02:21 AM
  5. using bobcad to create c axis g code?
    By stuart76 in forum BobCad-Cam
    Last Post: 08-15-2005, 11:06 AM
