Im in the process of making a slant bed cnc lathe from scratch up, involving, amongst other, some THK ballscrews bought off ebay. I can tell that they have been lubed with some white grease, but im thinking of changing to oil instead. This way the can be connected to the overall lubrication system. I have two questions now:
Should I replace the grease with oil in the first place, or should i just refill it with some more grease?
If I do connect it to the oil lubrication system, can I just flush the ballnut with a lot of oil to get rid of the old grease, while I run it back and forth the ballscrew? I may be able to remove the protective sealings.
