586,103 active members*
3,493 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > need technical information plz
    Mar 2007
    46
    for a stepper motor with this feature
    Type: bipolar / (unipolar)
    Current: 2.2 A (3.0 A) / Phase
    Holding torque: 1.65 Nm (1.3 Nm)
    Resistance: 0.9 Ohm / Phase
    Inductance: 2.2 mH / Phase
    Wave diameter: 6.35 mm
    Wave length: 19 mm
    and Driver with a 4 ampere used l6203 chip
    What are the characteristics of power supply that I use with only 1 card driver 4A + single stepper Current: 2.2 A (3.0 A) / Phase
    and what are the characteristics of power supply that I use with 3 card driver 4A + 3 stepper Current: 2.2 A (3.0 A) / Phase
    i ask this because my stepper heats more then 80 degree when i uses 6.8A 22V in 1 card driver and 1 stepper
    Mar 2007
    46
    Unhappy
    no man here
    Mar 2007
    46
    plz moderator close this topic
    24221
    Posting in the appropriate forum may help. i.e. Stepper Motors. .
    Al
    I will move it.
    Albert E.
  1. technical documents
    By phanuang_toan in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-27-2008, 09:57 AM
  2. A few technical questions about TC4
    By emvali in forum Bridgeport / Hardinge Mills
    Last Post: 10-07-2008, 09:24 AM
  3. DIY CNC Technical discussion
    By llilrex in forum DIY CNC Router Table Machines
    Last Post: 11-02-2007, 11:28 PM
