586,121 active members*
3,643 visitors online*
    Apr 2006
    1016
    ?? 4 fix gantry designs
    have a question about fix gantry designs
    ie moving tables, the home switch needs to be set up a little differently....
    so x, z home is over y home just like a moving gantry but
    the home is tripped to back of the table... so x,y,z are all on top
    of the same location... else y is homed to the front of x,z the distance of the table away fom the gantry.?
    Jun 2009
    37
    Essentially, all setups of home and limit switches are identical mechanically. They go near the end of travel of your axis. How you physically trip the switch is up to your application. In the case of a traveling table, I'd suggest that the home location be set with the table farthest forward on the machine, with the cutter at the back edge. The machine I used to program on was set that way. Y axis on the gantry would home to the right side, where the control station was, and Z was with the tool plate raised all the way. This facilitates easy table loading and tool changes.
  1. looking for designs
    By justin22885 in forum Musical Instrument Design and Construction
    Last Post: 02-27-2009, 10:00 PM
  2. Where can I buy plastic designs from?
    By noac in forum Glass, Plastic and Stone
    Last Post: 03-06-2007, 08:30 AM
  3. H bridge designs
    By R.thayer in forum CNC Machine Related Electronics
    Last Post: 02-15-2007, 08:06 PM
  4. Q: Y Axis - Gantry vs. "bridge" designs
    By Zoid in forum DIY CNC Router Table Machines
    Last Post: 07-06-2004, 10:35 PM
  5. r,theta,z VS x,y,z designs.
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 02-18-2004, 04:09 PM
