586,523 active members*
3,403 visitors online*
Results 1 to 8 of 8
    Dec 2004
    20
    proximity sensors
    Anyone know a good source for inductive proximity sensors like the ones used in Mach 2?. Thanks, John
    Mar 2004
    564
    what size were you looking for? Omron makes them, actually there are tons of manufacteur's out there, have you tried ebay?
    I might have a few I could sell depending on your needs/size ect...
    menomana
    Dec 2004
    20
    I'm not sure which type would be best. I was thinking about using the barrel style,( 4 or 5 mm). My machine is very simular to the shopbot.
    Feb 2005
    86
    I get a lot of other sensor stuff from www.automationdirect.com I know they have a selection of proximity sensors. I have been ordering sensors from them for the past 3+ years.
    b.
    Apr 2005
    Can I get 0.2 mm sensing distance with any of the proximity sensors?
    24223
    Sensing range is dependent on diameter and wether or not shielded type, with the shielded type the metal barrel goes right up to the face, otherwise there is a plastic end which allows slightly more detection range.
    Al.
    Albert E.
    May 2003
    40
    Jameco...
    http://www.jameco.com/webapp/wcs/sto...egoryId=354040
    I have been using the square green units for the past year with great success.
    They are connected to a Soundlogic breakout board.
    Tim
    Dec 2004
    518
    Wired,
    These can have different types of outputs and supply requirements. I've seen them with TTL compatible outputs, open-collector, etc. What are you wanting to tie them to? I guess maybe a better way to ask is what do the inputs your going to hook these to need/expect?
    Lance
  1. First CNC Machine
    By georgebarr in forum Uncategorised MetalWorking Machines
    Last Post: 11-09-2009, 06:35 AM
  2. Inductive Proximity Sensors-what are they?
    By Splint in forum CNC Machine Related Electronics
    Last Post: 08-01-2004, 11:24 PM
  3. capacitive proximity sensors
    By owhite in forum CNC Machine Related Electronics
    Last Post: 03-16-2004, 03:49 PM
  4. Proximity switches
    By bgriggs in forum DIY CNC Router Table Machines
    Last Post: 09-01-2003, 06:13 AM
  5. proximity switches
    By rcrabb in forum DIY CNC Router Table Machines
    Last Post: 07-21-2003, 05:27 AM
