586,119 active members*
3,603 visitors online*
Results 1 to 10 of 10
    Dec 2006
    947
    DIY 4th Axis Rotary Table
    I'm going to put together my own 4th Axis for my BP CNC and was wondering if anyone had experience doing this using a rotary table?
    Is this feesable? What should I look for, just backlash in the turning mechanism? Any suggestions on which rotary table to buy? Thanks.
    The problem I see right now is that most places don't stock this sort of stuff even harbor freight and I would want to test it out first, for the backlash before trying.
    Mar 2004
    1806
    I used my phase II RT to make it CNC. I found the backlash was quite adjustible and I could take most of it out. I still make the table run in one direction just to be sure. My use is more for indexing to drill holes etc and therefore use it only in the vertical orientation. The main reason I used this one is I bought it back before I could even spell CNC much less know what it was. It has worked very well for me.
    Art
    AKA Country Bubba (Older Than Dirt)
    Dec 2006
    947
    Thanks, the Phase II are a little more than I wanted to spend. But as I'm doing more research I realized what you said that most have some sort of backlash adjustment.
    Dec 2006
    947
    I was thinking about it, why do I need to use a rotary table and deal with all the backlash problems I'll have to address.
    I just ordered a Keling 576 oz/in. Stepper motor for the conversion and I was thinking what if I didn't use a rotary table and just use this
    http://littlemachineshop.com/product...2299&category=
    It's a small lathe head assembly. It's accurate all I would have to do is put on a 2" gear pulley on the stepper and a 5" or bigger gear pulley on the spindle. I think the amount of power from that arrangement would work nicely.
    Any comments, do you think this will work?
    Mar 2004
    1806
    If your going to use it as an "indexer", it would be fine. Depending on power required it might work for other uses also.
    Art
    Dec 2006
    947
    I would be using it for doing engraving and cutting pattern with my CNC Bridgeport. Do you think that'll work or not enough holding power between the stepper and a gearbelt?
    The motor and ratio you've mentioned would work fine for light duty milling up to a few inches OD.
    I've done some engraving with a 495 and it held strong.
    A larger ratio would be even better though.
    I've used my 4th axis mostly for making timing pulleys.
    It also works great as a lathe too.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Dec 2006
    947
    I went ahead and ordered a 4" rotary table from Grizzyly. I have a lot of their tools and trust them plus it says it has backlash adjustment. I have a new stepper driver and a 576 oz/in. stepper coming, oh plus I ordered a tailstock. So it should work well.
    Question I have an extra 4" 3 Jaw chuck and the rotary table is 4" am I going to have a problem mounting it? Any suggestions?
    HOSS, BTW for years loved your website you have truely given back to the community, thanks. Question for you what do you use to program your 4th axis stuff, like engraving?
    Quote Originally Posted by Cartierusm View Post
    I don't have a CAM program with 4th axis capabilities so I cheated for the engraving.
    I used Deskengrave to make the code then opened the program in notepad.
    Used "replace all" to change all the Y's to A's.
    I used the same technique for this job just took a lot more "replacing"
    Hoss
    Dec 2006
    947
    Cool, actually I caught Grizzly this morning before processing and canceled the order. I realized the tailstock I ordered was not the correct one, then I got to more thinking and decided to just buy the same head and spindle like on my HF 9x20 lathe. That way everything is interchangeable and if needs be I can just unscrew the chuck from the spindle on the lathe and transfer it over to the Bridgeport CNC. I'll use my new 570 oz/in. Stepper to drive it with reduction and a gearbelt.
  1. Rotary table 4th axis set up
    By usfwalden in forum Knee Vertical Mills
    Last Post: 08-16-2018, 10:25 PM
  2. How to install 4th Axis Rotary table?
    By MACKAY9999 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-28-2011, 09:47 AM
  3. Rotary table or 4th axis
    By mikemill in forum Syil Products
    Last Post: 05-13-2009, 09:47 AM
  4. Plasma Table and Rotary Axis
    By lmarkie in forum Waterjet General Topics
    Last Post: 12-13-2008, 07:32 AM
  5. 5 axis w/ lathe/rotary table
    By living-word in forum CNC Wire Foam Cutter Machines
    Last Post: 03-13-2008, 02:20 PM
