586,119 active members*
3,394 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > okuma howa nc5p fanuc 6t
    Jun 2009
    I recently took my turret apart to replace a seal. When I put it back together it flashes 99 over and over. It says in the manual that stands for double limit alarm. It also says the turret in position switch may be defective. The machine is a okuma howa nc5p with fanuc 6t. Any help would be appreciated.
    Mar 2009
    1982
    Most likely, You changed the turret index position (tool) while power off.
    You can release turret clamp and index turret manually and to find the correct position that way.
    Can You post full alarm message please?
    Are You sure, that You didn't ovetraveled both Z and X limits while servicing the turret?
    Re: okuma howa nc5p fanuc 6t
    Sorry this is a very old post I found but I have the same problem on my machine.
    Did you manage to fix the error 99 you had?
    What happened on my side was that the turret was out by one of the interlock teeth on the turret. So I opened the turret head to se If I can make any adjustments but found that it is controlled by the indexing unit which cannot be adjusted. After everything was put back together and I switched it on I got this error. Nothing moves. X and Y was not over travelled. Power was of while I did the changes.
    Any advice please.
    Is there anyone that has the operating manual for the Okuma NC-5P with fanuc 6t controls.
    Regards
    Juan
  1. Okuma & Howa Fanuc 6T Help
    By Kevin77 in forum Fanuc
    Last Post: 10-09-2020, 05:15 PM
  2. Replies: 2
    Last Post: 02-02-2013, 03:40 AM
  3. Anyone have a 511v Okuma Howa- Fanuc?
    By CAJUNCNC in forum Okuma
    Last Post: 04-11-2011, 10:04 PM
  4. okuma howa fanuc 6t controler
    By cncperfection in forum Okuma
    Last Post: 07-25-2010, 02:38 PM
  5. Okuma Howa ACT 2SP V5 with FANUC 18T
    By marklosch in forum Okuma
    Last Post: 01-20-2010, 01:14 PM
