586,103 active members*
3,339 visitors online*
    Jun 2009
    siemens 840d/Wimdows
    Help
    Is der some one ho cam tell me how to go in to windows on a simens 840d controller
    Jun 2010
    I don't know if this works for you, but recent versions of Siemens works over windows, the easiest way I know to enter in windows mode is when the machine is booting and loading sinumerik the bottom bar (windows bar) appears for a second and a half and you only have to press "3" on the console when that happens.
    Oct 2009
    34
    Went you start the control between the memory test and the windows running push the number 8 or 6 and some menu will show the give you access to the windows.
    If you need anything else please let me know.
    Information
    hi tell me please that which machine data is used to activate or deactivate the sinumerik date and time softkeys....please reply my post
    thanks
  1. Need Siemens 840D Help
    By gears2010 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 07-25-2013, 03:54 PM
  2. SIEMENS 840D
    By BKCOM in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-08-2010, 11:21 PM
  3. VB & Siemens 840D
    By Thunder in forum Visual Basic
    Last Post: 09-22-2007, 04:28 PM
  4. Need Help, Siemens 840d Right Angle
    By montyleeclark in forum Post Processors for MC
    Last Post: 07-19-2007, 03:23 PM
