586,077 active members*
3,679 visitors online*
IndustryArena Forum > CAM Software > Mastercam > need Autocad .dwg file converted
Results 1 to 13 of 13
    Feb 2005
    6
    I need it converted to MasterCam 8. Any help apreciated.
    Attached Files Attached Files
    Jun 2004
    450
    both files seem to be blank.
    anyone else try them?
    50
    Try this. There are mc8 files in the zip. Looks like T-Maxx parts.
    Nov 2004
    166
    RcCNC, I looked at the files, and tried to make them into solid models in Surfcam, but they wouldn't extrude. I found that they had some "dirty" geometry in them; that is, some overlapping entities, and endpoints not trimmed together, as well as some tiny pieces of geometry not visible unless you zoom way in. These things can cause you problems when you want to "chain" the profiles for machining. If you want to fix them, look for those things. If you want any help, I'd be glad to clean 'em up for you.
    Bill
    Jun 2004
    450
    I wonder why I can't open them. I tried to open them with Rhino and mastercam. Didn't work with either of them.
    Feb 2005
    6
    Thanks all
    Bill If you would kleen those up for me I would greatly apprectiate it. i can only work on them at school and thats only for 45 minutes. they were only drawn in 2d but if you convert them to 3d the thickness of the peices are 1/4"
    I am still new at machining. I only get practice at school in my metal shop and i've only been messing with it for a few months now
    thanks again!
    Nov 2004
    166
    RcCNC, here ya go.
    Feb 2005
    6
    Thanks alot I cant check them out right now at home but i will first thing tomarow morning and let ya know if/how they turn out.
    thanks for all the help and let me know if there's anything i can help with. (but like I said I am new at this so iam still prity slow)
    Feb 2005
    6
    BILL H
    Every thing worked good but i need the a-arm with the large ovals (dont remember what i called it) I need the another 1/16 inch between the inside of the outer tabs and outside of the center tab. it also needs to streach the ovals with it.
    Feb 2005
    6
    Actually i think that if just those Oblonge holes are made another 1/8 " taller than every thing will be O.k. thanks
    Nov 2004
    166
    RcCNC, I PM'd you. I'll take a look again at the DXF files and see if I can get the changes in there.
    Quote Originally Posted by RcCNC
    Nov 2004
    166
    RcCNC, I got the original file from your first post and re-drew it. I'll attach a pic with the dimensions in question (plus a few others!). Lte me know which features you want to change.
    Feb 2005
    6
    a arm corrctions
    here they are
  1. How do i get my autocad file onto mastercam?
    By EdE in forum Uncategorised CAM Discussion
    Last Post: 02-23-2011, 06:54 AM
  2. Emco Compact 5 PC...have ????
    By Double G in forum Mini Lathe
    Last Post: 08-23-2010, 12:26 AM
  3. Do me a favour ( DWG-DXF Conversion)
    By ynneb in forum G-Code Programing
    Last Post: 04-07-2005, 02:04 PM
  4. Poor Mans Autocad solid converter
    By CAMmando in forum Mastercam
    Last Post: 07-17-2003, 02:10 PM
  5. AutoCad 2000 Missing .dll file
    By E-Stop in forum Autodesk
    Last Post: 05-30-2003, 05:43 PM
