I am saving up to buy a 10x22 and can get one for cheaper than usual but it only has a 3/4HP motor on it.
I can get a 3HP 3Phase 240V 56T frame motor and 0-400Hz VFD for around $475 but is the 10x22 built well enough to handle a 3HP motor??
Also I imagine this will drastically alter the lead/feed rates for threading as I imagine they are geared directly off the motor (1725rpm I imagine) and the headstock is geared separately. If I alter the motors speed I would need to do some math to match feed/spindle speeds or set the motor to the stock speed whenever I want to cut threads right?
I would appreciate a picture of the gears setup of the 10x22 and anyone's experience with a VFD and threading by hand.
Thanks!
