586,617 active members*
2,528 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Newbie needs help! cutting acrylic, and double cutting? 3040 machine
Results 1 to 6 of 6
    Jun 2009
    12
    Hi all, I recently received a 3040 laser cutter/engraver and i'm just trying to get use to using it, and getting it to run correctly.
    I have aligned the mirrors as best i can (took me hours) and have managed to cut some cereal packet card with power=5, speed=35. Had a few problems with the card setting alight, but i think i've figured it out, do these settings sound alright?
    Now i'm trying to cut 3mm acylic. Can anybody let me know what power and speed settings they use for this? I jus can't seem to figure it out. When i get it to cut right through, the edges are kind of melted and not good.
    The other thing i'm worried about is that occasionally when i try to cut, there will be one line as expected, and then another fainter line engraved about 5mm away from it, anyone know what might be causing this?
    I am completely new to all this, so any hints and tips are welcome!
    Thanks guys.
    x
    Jun 2007
    3757
    3mm acrylic.
    Saw acquaintance laser cutting (literally tons) acrylic yesterday.
    I asked id he use air, and he said just enough to stop it catching fire.
    Underside supports were made from plastic. Metal points got hot and damaged underside.
    Aug 2008
    82
    Quote Originally Posted by stephaniehamer View Post
    Thanks guys.
    x
    Hi Stephanie,
    Do you have an air assist cone on the laser head?
    I have seen this when the beam is not aligned correctly through the last mirror. It exits the focussing lens off-centre and reflects off the side of the air assist cone.
    Regards
    Dave.
    Feb 2005
    469
    I think she was asking about speed and power settings for 3mm acrylic. I don't have a 3040 so could someone suggest a setting to try?
    Jun 2009
    96
    When the laser beam is correctly straight, you can set the power bigger, becasue you want to cut the acrylic, you have to set the power bigger, and speed slower.
    www.roc-tech.net
    Apr 2009
    39
    Check that you've got the material at the right height so that the laser is focussed on the top surface of the material?
    dvdlock might be on the right track with this and in the same way that you put things over the mirrors to see where the beam was hitting them, you can remove the 45 degree mirror on the head (and put something in it's place) to check where that is being hit, and over the bottom end of the head (take the lens out first) to see where it's going down there.
  1. Cutting Acrylic
    By Gujustud in forum Glass, Plastic and Stone
    Last Post: 01-28-2009, 02:05 AM
  2. Newbie Questions - Assembly Laser Cutting Machine
    By watxup in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-01-2007, 04:00 PM
  3. laser cutting acrylic - art application
    By charper in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-07-2006, 07:50 AM
  4. I need help about cutting heads which apply to apparel pattern cutting machine
    By sheepgrass in forum Mechanical Calculations/Engineering Design
    Last Post: 05-12-2006, 07:09 PM
