586,110 active members*
3,173 visitors online*
Results 1 to 8 of 8
    Dec 2004
    43
    Anyone using Hobbycnc boards for plasma?
    Is anyone using Hobbycnc boards for their plasma?
    Are 200 oz/in motors sufficient for a 20 lb gantry?
    John
    Nov 2004
    71
    I think you could. I use a Xylotex & 187oz motors to push a 55# gantry 90ipm max. I figure that it would take 400oz motors to push me to plasma speeds, but with a light gantry, 200oz could probably do it. MIKE
    Apr 2003
    540
    It'll work fine. Just use something like 5 tpi ballscrews/nuts. I upgraded from acme screws to ballscrews and with a xylotex board and 270 oz steppers I can now rapid at 420 in per min with no lost steps using mach 2. A plasma torch is a lot lighter to push around than my router...
    -marc
    Jun 2003
    114
    Quote Originally Posted by coherent
    -marc
    Hi mark,
    could you post dome pictures of your table?
    Regards,
    Hector
    May 2004
    198
    -marc
    Anybody consider the electrical "noise" from the plasma torch?
    Dave Rigotti
    Nov 2004
    71
    Quote Originally Posted by hobbycnc
    Dave Rigotti
    Dave, why don't you enlighten us ? Is plasma noise a "deal killer" with your boards ? Others that you know of ? Just curious. (Luckily, I have no torch noise to deal with) MIKE
    May 2004
    198
    Quote Originally Posted by accuratemike
    We've never had any feedback from users and I don't plan on making a Plasma machine to test it. I do know of other drivers that have had trouble with. Thats all the enlightening I can do.
    Dave Rigotti
    May 2003
    64
    The problem with plasma cutters is the EMI can cause false triggering of the the step motor drivers. What seems to be unanimous is that the hypertherm higher frequency is less of a problem that other brands. Careful earth grounding of the plasma cutters frame, the plama cutter itself grounded to the same earth connection and shielding the pc are just some of the ways to prevent lost stepper/ interference from the plasma torch.
    Dan Mauch
    Camtronics Inc
    [email protected]
    www.seanet.com/~dmauch
  1. hobbycnc board
    By wjbzone in forum CNC Machine Related Electronics
    Last Post: 09-08-2012, 05:07 PM
  2. Is anyone using Hobbycnc boards for plasma?
    By johnt in forum Hobbycnc (Products)
    Last Post: 03-27-2005, 03:17 AM
  3. HobbyCNC 3 axis board build and review
    By Jay C in forum Hobbycnc (Products)
    Last Post: 02-19-2005, 05:22 AM
  4. help with boards
    By mocnc in forum CNC Machine Related Electronics
    Last Post: 02-18-2005, 03:18 AM
  5. question about 2 X 2axis boards
    By Stevie in forum CNC Machine Related Electronics
    Last Post: 03-15-2004, 01:39 AM
