586,103 active members*
3,382 visitors online*
Thread: Work Light
Results 1 to 6 of 6
    Jul 2008
    116
    Work Light
    I have two hyundai Kia vx500 Machines that the work lights will just sit and flicker and will not turn all the way on. If anybody has a solution to fix this I would gladly listen
    Thank you,
    Kyle
    You must remember that 99% of my posts are Bullchit!
    Aug 2007
    339
    Sounds like a bad connection. I'd take out the bulbs and clean the contacts, try that. If that doesn't help they might just need to be replaced. Do not touch the blubs with your bare hands. The oils on your skin will cause the bulb to blow when you turn it on. Wipe off fingerprints with alcohol.
    Jul 2008
    116
    The bulbs are not halogen they'er fluorescent I tried the starters but didn't fix it i was thinking if it had a balist maybe not wouldn't even know were to start looking for that.
    Aug 2007
    339
    I didn't realize they were fluorescent. But you're right in thinking ballist maybe the problem if it has one or the starters. Bad starter will cause flickering. Did you check the pins in the bulb for corrorison? That green stuff.....
    Aug 2007
    339
    You might want to try some dielectric grease on the connections also...it helps.
    Jul 2008
    116
    Had the teck. in today and confirmed that the ballast in both machines are junk and kia won't sell just the ballast have to buy the light so I will have to figure something else out
  1. Replies: 6
    Last Post: 10-26-2008, 12:16 AM
  2. VF-2 Work Light Out
    By akedward in forum Haas Mills
    Last Post: 02-19-2008, 07:37 PM
  3. Work light connector over heating
    By GITRDUN in forum Haas Mills
    Last Post: 08-29-2007, 09:54 PM
  4. Machine Recommendations Please - Light Duty, Prototyping, Light Production in metal
    By SCG11762 in forum Uncategorised MetalWorking Machines
    Last Post: 08-27-2007, 02:08 PM
  5. Chicago: Access to shop in return for light work
    By vacpress in forum Mentors & Apprentice Locator
    Last Post: 11-15-2006, 05:43 AM
