Dear All,
i face the following problem in measuring face mill in my TAKUMI CNC machining center
the control is Fanuc 0-imc
problem description :
when i try to measure an end mill i write in MDI the following command,
G65 P 9954 T1;
while G65 : macro call
P 9954 : is macro program number
T1 : tool number 1
till now i have no problem, the problem is in measuring face mill tools which have multi insert.
when i write in MDI the previous command, the inserts of the face mill does not touch the "tool length measuring device" .
i must stop the machine during measuring cycle and move X axis by Manual Pulse generator to make the inser touch the "tool length measuring device"
i need the command by which i can measure the face mill tools with an automatic cycle.
is the problem clear ??
if any one can help me it will be very good.
Note : attached here the macro program if any one want to check it
