Hey all,
I was on the verge of building my own CNC based off of Joe's plans, but stumbled onto a machine on Kijiji at a good price. The only problem with it is that it lacks the BOB/controllers. The basic story is that the gentleman that built died, and I bought it from his son. He couldn't find the original controllers. So basically I am hoping you guys can help me pick a controller to use with this machine.
My uses will be to use it on solids and some mdf/PB. It has a small ryobi router in it but I will need to replace the entire plate it sits on to put in a new router as its coupler is braised to the plate.
So I guess pictures are in order. I really do not have a lot of information on the build or what parts are made of. I am hoping that the community can help me identify a few of the parts.
The 3 motors are 'japan servo co kp86sm2-002'
http://www.used-line.com/c6120527s10...vo_KP86SM2.htm
They are 4 wire motors. The X and Y are belt driven with gears. Anyone need me to count teeth and give the diameters of the gears? The Z is connected by a lovejoy.
The transformer just has a serial code on it. I tried googling it, no luck. Would the power of it be marked?
I'll also post a pick of the screw with a tape measure. It took me a little bit more then 5 turns(very little) to move the Z 1". I am fairly certain these are acme lead screws, but there seems to be a small groove along the centre of the thread.
So pics! the base is 3'x3' with 5"-6" for the Z.
Please request anymore pics that are not in this post. I'll give you the best information I can. I wanted to get a HobbyCNC controller, but that is only for unipolar 5,6, or 8 wire motors. Can I do a Gekco? I am also considering using a design off of Pmino's website, but I cannot tell which board to pick. I know I would need a bipolar one, but I am always confused by which one would suit me best. Also as too how much voltage I need.
