586,357 active members*
3,631 visitors online*
    Sep 2008
    10
    question about 4th. axis
    We have a VF1 mill with the HA5C indexer. Is there any way to zero out the indexer to a different position. I indicated a part flat last night and it was aprox. 8 degrees off zero and I wanted to set a zero there but I could not figure out how,I know with the seperate control box it can be done but I'm not sure how to with the indexer wired directly into the machine.
    Mar 2008
    638
    Does the "A" axis show up in the offset page?
    If it does, zero out the part and press the "Part Zero Set" button.
    Feb 2009
    64
    Offset
    Additional axes are set to work offsets the same as the traditional x,y,and z axes.
  1. Rookie Question...3 axis vs 4 axis controller
    By Ferrari2007 in forum DIY CNC Router Table Machines
    Last Post: 09-14-2009, 02:04 AM
  2. x axis question
    By nasrace10 in forum Commercial CNC Wood Routers
    Last Post: 02-20-2009, 02:12 AM
  3. Question about Z Axis
    By jfunk56 in forum DIY CNC Router Table Machines
    Last Post: 05-03-2008, 02:10 PM
  4. Z axis question
    By Ric_A in forum Machines running Mach Software
    Last Post: 06-05-2006, 01:27 PM
  5. 5 axis question
    By turmite in forum Mechanical Calculations/Engineering Design
    Last Post: 11-06-2005, 11:34 PM
