586,121 active members*
3,761 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC Wood Router Project Log > 2AM: I wonder if the table saw will wake the kids...
Page 1 of 8 123
Results 1 to 20 of 141
    Feb 2005
    521
    Welcome to my first router/mill/cnc project.
    With 2 young kids and busy job, build progress is not going to be meteoric. By the time the dragonlets are abed, kitchen tidied, dog walked etc, I'm doing good if I can get into the garage by 10pm (sleep deprivation permitting). I see by other posts I'm not alone in this. What is this 30ish post baby bloke thing?..."Urrrh tired...urrrgh...must...make...CNC macheeen!"
    I've recently acquired a 7x12 mini lathe that I'm trying to get to grips with but my turning ability is currently only marginally better than my welding (which looks like something a bronchial volcano might spit out).
    I've decided to go for an aluminium build; mainly because I'm sick of the sight of MDF after using it in a number of household projects. I still disturb the occasional drift of MDF dust when exploring the darker depths of my garage. MDF also == painting (me no likey).
    So without further ado, here is a rather amateurish CAD drawing of my design
    (complete with magical floating motors!)
    The slides rails are from old printers, the aluminium is from some rather chunky extrusions I blagged from a local business. The Y carriage is initially going to use a pair of bushings from the printers and the X is going to use a rather shonky design I came up with using blocks with 2 pairs of roller bearings that run on the rails on their chamfered rims. A prototype I made of this tells me it should work but my rails are going to end up badly grooved and zoner Splint also points out the excessive thrust load on the bearing. I'm going to build the Y axis and gantry first so I may change my mind when I get to the X.
    (I do hope I've got my X and Y nomenclature the right way round...I'd hate to come across as a dumb newbie...even if I am
    (the zip file contains a dxf)
    Regards Andy
    Attached Thumbnails Attached Thumbnails 10bulls mill 3D 2005-02-15.jpg   dodgy-linear-bearing.jpg
    Attached Files Attached Files
    Feb 2005
    521
    Progress over the weekend was not great.
    I spent what little time I had farting with the table saw trying to get accurate, square cuts in the aluminium profiles. I have come to the conclusion that this is not a precision machine. Fortunately my design doesn't call for anything too accurate, apart from the 2 cross pieces for the gantry. On top of this, wifey found lots of aluminium chips in the sack of potatoes in the garage (nuts)
    The 'L' profiles are actually cut offs from some hefty profile shaped a bit like |_|'''|_|
    It was a bit of a buttock clenching experience feeding 4ft x 10in lengths of the half inch thick profile lengthwise down my aforementioned wobbly table saw. Yay Ear Defenders!!!
    Another frustrating experience was trying to cut off blocks from a 1" by 0.5" steel bar using a cheap gadget that clamps an angle grinder to make a sort of poor man's chop saw. It works dandy on 2mm box section but took several minutes to hack, burn and wobble it's way through the solid bar.
    I've since cut all the blocks using a hand hack saw which went surprisingly well in a hand crampingly sort of a way. Yay Hacksaws!!!
    Attached is a picture of some of my raw ingredients.
    The grey bits bottom left are the bushings for the Y slides. They are going to be a pain to mount as the bit with the mounting holes is not really flat and the only flat sides don't have enough metal to tap holes into. Learning to make accurate bushings, pillow blocks etc is definitely a priority after phase 1.
    Also shown is a stepper I'm going to use initially and a servo I'd like to use eventually. The stepper is connected to PIC16F84 + L298N boards I designed a few years back. (look at the purdy spinning motor go round and round and round and...)
    I like the look of the PICStep boards that Alan (Garfield2) has created and I'm hoping that if I keep telling him what an extremely clever, generous and ruggedly handsome individual he is, he may let me try his PIC Servo design
    Aug 2004
    2849
    Hey good work. Generally the gantry has the Xaxis and the Zaxis and the table is the Yaxis.
    Got the wife, the kids, the pet....yep, been there....now gotta have some creative fun.....tools......mechanical marvels connected to electronic gizmos.....yeehaaaaa!
    Quote Originally Posted by ViperTX
    I think it's the other way around. Usually the gantry is Y and the table is X. It will work either way just fine. I've heard that the proper method is to designate the longer of the 2 axis X, and the shorter one Y.
    Mar 2004
    190
    If I am not in a mistake, the explanation was in one of ballendo's post and talks about designating X not the longer axis but the one that can bear the largest raw material
    /F
    Feb 2005
    521
    I hadn't realised this confusion on my part would open up such a can of worms.
    At peril of ruining my parts by machining them 90 degrees off I have hereby decided
    to introduce a much less ambiguous naming convention.
    The long axis will hence forth be called John (as in 'long'...get it?).
    I decided against calling the Y axis Jesus (goes across) on the grounds it might offend and lose me some friends, so I decided upon Paul.
    This results in what was my Z axis is now known as Ringo and my CNC rotary table
    (should ever I be blessed to live to see it built) will be called George.
    Regrettably this does limit me to building a 4 axis machine as
    A) I can't remember the name of the original drummer who left and...
    B) I couldn't tell you what a 5th axis might be even if one came and danced on my lap.
    Nov 2004
    389
    Hey Andy,
    Good to see you have started your thread and have added some light hearted humour to the forum. Quite entertaining !
    I imagine the debate over the axis names is not over
    I had an issue trying to get square cuts on the aluminium profile too. Thankfully I bribed a friend and he milled the ends square, (Just as well - they were not pretty)
    I can sympathise with you about time and kids. Never enough to time to get the Geeky stuff done....
    I look forward to following your entertaining thread....
    Aug 2004
    2849
    Well the Cartesian coordinate system doesn't care...just put big labels on your axis so when you take pics and talk about stuff everyone....well most everyone will remember the coordinate system you're using.....The only time you'll run into problems is when you go from someone elses CNC mill, to router, etc.
    80/20 always does a good job on cutting their extrusions....I wonder what their local dealers use for a table saw...the blade is a triple grind carbide tipped blade.
    Oct 2003
    593
    Hi. I'm enjoying your thread. Good start. It's nice to see another UK CNC builder entering the arena. What length and diameter are those printer rods, your bearings are running on?
    I've got a machine built, but it needs some fine tuning, alignment wise. Will hopefully get more done at the weekend. (kid, dog, cats, work, etc, etc....) You can see it here:.....if you're interested.
    http://www.terry-is.f2s.com/
    Keep the updates and pictures coming. Looking forward to watching your progress.
    Regards Terry.....
    Mar 2004
    564
    I always use the right hand rule when describing co-ordinate systems, for fun I typed it into google and the first link below actual gives some good visuals for co-ordinate systems as well as g-code explanations.
    The second link I stumbled accross is just cool, 5 axis cnc machine (home made)
    http://www.media.mit.edu/physics/ped...-tutorial.html
    http://www.rainnea.com/cnc.htm
    menomana
    Mar 2004
    564
    Ooops...I made a mistake, althought the first link does provide good information, this was the link I ment to show.
    http://www.utm.edu/departments/engin...cture%2025.pdf
    menomana
    Jun 2004
    450
    *edit* sorry noticed topic was straying a bit.
    10bulls welcome. You've got one necessity that is mandatory to be a machinist.....a good sence of humor.
    Aug 2004
    2849
    yeah, you just have to remember which finger is which axis....which I do by thinking 2 dimensionally on graph paper....side to side is x and up and down is y.....so poking you in the eyes is z....
    Feb 2005
    521
    Quote Originally Posted by santiniuk
    Good to see you have started your thread....
    Thanks for the encouragement. I'm determined to try to catch up with you...It will good to have someone to share trials and tribulations with.:cheers:
    How's you're build going? It's looking good so far. I'm dead jealous of your skip booty...you've got a much better class of trash in your neck o the woods.
    Feb 2005
    521
    Quote Originally Posted by MrBean
    Thanks...been following your posts too, most heartening. :cheers:
    I have 2 x 17.9mm diameters and 2 x 17mm diameters, all around 500mm.
    I may need to bolt in some supports to help with deflection...if they survive long enough!
    I've got a machine built, but it needs some fine tuning, alignment wise....
    Seen your stuff. If mine turns out half as well I will be pleased.
    I'm looking forward to my first chips, but not relishing the calibration stage.
    Just checked out your site...great stuff!
    After buying the odd bit of aluminium lately my next project after this is definitely going to be a foundry...even if I only cast simple plates and bars for machining. Prepare to be brain picked on that at some point.
    PCB milling, wind turbines and cooler blocks are also high on my list of 'wanna dos'. Hee Hee...I see I even have the same multimeter as you! SPOOKY!
    Regards
    Andy
    Feb 2005
    521
    After ruminating on how to accurately position my printer bushes on my Y (Paul) carriage, I concluded that I needed a better way of laying things out. I had put 2ft square granite surface plate on my Santa list but received some 8 year old Glenmorangie instead (Oh the things a chip sweeper must endure!)
    So last night I got a little side tracked and bodged up a surface plate using a piece of glass on my table saw table and I made a surface marking gauge from vee block, 8mm printer rod and some bits I turned on the lathe. It works! Precision engineering here we come!
    It was good to get some more turning practice. My lathe had been feeling a bit neglected lately as it has been a few weeks since my last practice session, when I learned to make a solid metal cylinder from a slightly larger solid metal cylinder.
    After slicing my thumb last night, on the edge of the turned steel round (man that's sharp!), and bleeding over most of the drills and taps used thereafter, I
    decided that the subject of my next lathe master class will be chamfering.
    Attached is a photo of last nights efforts, together with a particularly fine piece of drill swarf I am rather proud of.
    Also shown are the printer bushes (or is it bushings?) and Y carriage plate. My plan is to bolt the bushes to the steel blocks then bolt the blocks to the carriage allowing for some adjustment. I'm a bit worried that the bushes with flex outward so I may consider using some epoxy on the flat bottom surface (though won't be able to adjust once set) or add a sort of clamp to hold them both down.
    Gotta go away for a few days now ...no more progress til I get back.
    Dec 2004
    1137
    Quote Originally Posted by 10bulls
    After slicing my thumb last night, on the edge of the turned steel round (man that's sharp!), and bleeding over most of the drills and taps used thereafter, I decided that the subject of my next lathe master class will be chamfering.
    Actually all you need to do is break the edge with a file while it's still in the lathe. Look here under Filing the Edge at the bottom of that page.
    Jay
    Feb 2005
    521
    [excuses]
    Pretty pitiful progress to report I'm afraid. After a trip to Wales to visit the dragon-in-laws for a few days, my wife and I and eldest all came down with a stomach bug kindly donated to us by youngest who had recovered from it a day or so previous. Only amusing highlight was the look of fascination on youngest as she pulled herself up and peered down the loo to see what it was that everyone was shouting at down there.
    [/excuses]
    So after rugging up my simian attachments I braved the garage last night and managed to drill a few more holes. I've marked out the Y carriage and made mounting blocks for my odd shaped printer bushes. Seems to hold the bushes well, though I'll probably slosh some loctite about once everything is aligned.
    Jan 2004
    490
    Don't look down on yourself. Even "pitiful" progress is better than none at all. Just keep pluggin.
    Stop talking about it and do it already!!!!!
    Nov 2004
    389
    I guess we picked the wrong time of year to build these crazy things Andy.
    I think any progress is worth reporting so keep it coming. Sometimes sparks a discussion that gets entertaining. Just don't mention Brass Monkeys
    Good work on the assembly. I like the concept.
    Cheers.
Page 1 of 8 123
  1. Trade offs between Moving Gantry and Moving Table
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 04-22-2011, 07:48 PM
  2. 5th even 6th axis? how does it work
    By ToMMY2ooo in forum Uncategorised MetalWorking Machines
    Last Post: 10-04-2004, 09:58 PM
  3. Aligning cross table is driving me crazy. Ideas?
    By pigifly in forum Uncategorised MetalWorking Machines
    Last Post: 07-07-2004, 08:45 AM
  4. Cost / Price of a DIY CNC table.
    By Havic in forum DIY CNC Router Table Machines
    Last Post: 03-01-2004, 09:08 PM
  5. Sanity check- 6'x10' table
    By Zephrant in forum DNC Problems and Solutions
    Last Post: 05-13-2003, 05:09 PM
