I am trying to do a 3/8" NPT using the hole wizard. The only problem is that is is not in my list of threads. Is there anyway to add it.
Randy, you should not have a problem with the 3/8 NPT as it is a standard size for SW.
When you enter the holewizard and select the tapered pipe tap option you should see it in the hole specification list.
What version are you using? Please see the attached pic....
Paul
Thanks for the response. I do feel kind of like an idiot. I figured it out not long after making this post. I just never used the feature and did not no where it was at. Again thanks for your time.
