I and J are the X and Y coordinates of the arc center, so you need both values, typically correct to whatever tolerance the machine is capable of holding.
You also need to know whether the control expects those arc center coordinates to be incremental (relative to the arc endpoint), or whether they must be absolute coordinates, based on the work datum.
