586,047 active members*
3,801 visitors online*
Results 1 to 16 of 16
    Feb 2005
    44
    Design Considerations...Basic!
    This seems like a very basic question, and I can't find a decent answer.
    What would be my design considerations when choosing a;
    "Moving table" over a "moving bridge" or vice versa?
    Please correct me if I'm wrong, but I think I have found examples of each;
    Bob Campbell "moving table" : http://www.campbelldesigns.com/
    Data-cut "moving bridge" : http://www.data-cut.com/Page2.html
    Thanks!
    Michael
    746
    Yep, thats it.
    6855
    The movable gantry to me is a bit more complex than a sliding table, the sliding tables disadvantage is the extra foot space, needed to allow for table movement. The fixed gantry would make for a very ridge machine. The movable gantry is the most popular and can me made so many ways. Their are many great examples here on the site of many machine that will give you many ides.
    Feb 2005
    44
    Please let me know if the following is accurate;
    A movable Gantry or bridge is more complex, less sturdy, but has a smaller footprint than a fixed gantry or bridge. The fixed gantry or bridge requires more space, is very sturdy, and less popular. Hmmm....
    Is there a major price difference between the two designs other than the components one would choose to go with Ie. Steppers, rails, lead screw vs ball screw, etc. I would think a movable gantry would require more components to construct? but then again I'm no pro when it comes to CNC routers (if you couldn't tell... )
    Where would one go to gander at how all these systems work? I have been reading a lot in regards to these sweet machines. However, I'm still not sure how all the components "fit" to complete the "rolling chassis", if you will. I guess one could say that I'm a visual (picture) learner.
    I appreciate the help.
    Nov 2004
    260
    Smile
    Quote Originally Posted by Nonoriginal
    First part of you question is mostly incorrect exept for the added space
    requirement.
    Both systems are allmost identical in there requirement sturdyness and cost.
    Think out of the box, forget about moving or not moving gantry and concentrate your efforts on the things that matter.
    Transfer of power from the table to your motormounts, use the most efficient
    sturdy structure between those components as your requirement calls for.
    In the end if you have a moving bridge or a fixed gantry will simply depend
    on where you decide to mount the legs onto.
    Good Luck
    A moveable gantry can be made just as stiff as a fixed gantry. It may not be as easy to do, but it can be done. Most people go with the moving gantry because you only need about 60% of the length for a given cutting length. You'll also need a longer linear bearing setup for the moving table, which could cost a lot more if using high quality components.
    Nov 2004
    78
    IMO, if you've got a requirement for having a rigid, accurate machine then both the moving gantry or moving table designs give ample opportunity for problems
    Personally, I like the idea of having a moving gantry and a fixed table mainly because I can picture down the road wanting to swap out features on the table (like a vacuum system, clamping fixtures, etc) and it seems to me that it would be easier to do that sort of thing when dealing with a 'passive' table.
    Also, on a larger router the idea of accelerating and decelerating a big, heavy table with another couple hundred pounds of wood or metal on top isn't too appealing.
    Finally, as ger21 stated, getting the cutting envelope covered by a moving table on the x-axis means that you need a set of linear rails that are 2x the length of the table. For anything over a 24" table, the cost of those rails (even on eBay) is going to be tremendous. Plus the cost of the ballscrew.
    -Chris
    6855
    Some of the better professional wood machines I have seen and operated were all movable tables, they will accelerate much faster than a gantry type, they only have to move a table not the gantry motor etc. With a fixed gantry you can build that so stiff and heavy that you can reduce vibration that would only travel though the components that make make up a movable gantry. For small hobby machines movable gantry is what I would go with.
    http://www.thermwood.com/twood_site/...nc_routers.htm
    Nov 2004
    260
    Quote Originally Posted by ger21
    Hi ger21, I just read your post from a different thread, looked
    at the link you left there.
    http://www.k2cnc.com/machines/KG-3925_detail.html
    Nice Machine pictured on the Page.
    This Picture pretty much makes the point I was trying to make
    it shows a basic machine structure without any legs mounted.
    A very good design I might add.
    But the machine still can be used ether way depending on where
    you chose to mount the legs to.
    Mount then on the ends of the Table and you have a moving gantry.
    Mount then spread out to the gantry itself and you got yourself a
    fixed gantry with a moving table.
    The components of the machine structure itself remains absolutly
    itentical.
    Feb 2005
    44
    Thanks for the replies!
    Ok, here is another question;
    What are the pros and cons of a pillow block bearing system on rails vs. a linear slide system like THK, for example?
    Do I lose anything signifigant besides static load capacity?
    The reason I ask is due to my visit at the liquidators this morning. I have 4 Thompson super twin 12 open pillow block bearings (mounted on 36" SS rails) on hold until tomorrow morning. I'm not going to say the price until they are in my grubby hands.
    thanks,
    michael
    Jan 2004
    490
    If the rails are supported, they should be a good buy. Well...it would be a good buy if they cost less than $25 for the whole kit.
    I'm kidding!!! If you get a good buy on them, they sound good. If they are supported. Sounds like you are getting a pretty good handle though. Still plenty of hurdles left, keep at it...BTW, if they are supported...
    Stop talking about it and do it already!!!!!
    Feb 2005
    44
    They come with a shaft that is pre-tapped for a guide rail. I see no way of supporting it, other than milling out a section to mount them in Aluminum. I see why most use a linear sytem. Its much simpler.
    Do you have any ideas to make it work?
    You can buy the supports from McMaster-Carr. They are exspensive, but you could buy 1 and cut it into small sections, as you probably don't really need it to be fully supported.
    Feb 2005
    44
    I have been trying to design the gantry, but I'm running into some problems.
    The pillow blocks measure 2.75" x 4.50". I have a plate of 16"x16"x1" 6061-T6 that I would like to make my gantry sides with. Is one pillow block enough to support an 8"x1" gantry side*? Or should I cut my Sides down to 6 inches?
    *The Thompson spec's say a static load capacity of 940lbs per block.
    I drew this little gantry this afternoon. Its modeled after Beezers CNC rig. I would use some .5 6061 plate as outside gussets to stiffen the back side.
    Jun 2021
    17
    Re: Design Considerations...Basic!
    Movable gantry vs movable table:
    Very simplified:
    CNC Mill (metal) = table
    CNC Router (wood) = gantry
    It all comes down to weight and speed at larger sizes.
    Let's say you want to route a 4x8' piece of oak. Speeds high for that, softer material than metal, lighter gantry possible. What weights more to move: the spindle gantry or the work? Also if the table moves you need a 8x16'. Gantry solves this.
    What about a 6"x6" metal work? Need precision and slow speed. What weighs more to move: the precision metal gantry, or the much smaller metal work? Table solves this.
    At larger sizes it becomes clearer.
    For smaller build sizes in wood or metal it may not matter as much.
    1225
    Holy thread resurrection Batman! sixteen years after the last post a new comment rolls in.Maybe our new member has facebook blocked, as I do,and it takes forever for a page to load.
  1. CNC Lathe Considerations: bed design
    By cncadmin in forum News Announcements
    Last Post: 02-13-2014, 08:50 PM
  2. 8' X-axis, Design Considerations
    By hkinkade in forum DIY CNC Router Table Machines
    Last Post: 08-08-2012, 01:37 PM
  3. Supported Rails Design: Y & Z considerations
    By pippin88 in forum DIY CNC Router Table Machines
    Last Post: 09-07-2011, 09:23 AM
  4. Need some basic design and build input
    By Dman65 in forum DIY CNC Router Table Machines
    Last Post: 08-04-2011, 12:01 AM
  5. Basic Design Help $$
    By Dustynb in forum Uncategorised CAM Discussion
    Last Post: 03-13-2008, 07:53 PM
