587,056 active members*
3,729 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam X2: Tool Plane must be set to Top or Off in entry
    May 2009
    27
    Hi there,
    I have one problem with Mastercam and maybe any member can help.
    Creating Toolpath for a simple Pocket I always get this alert:
    "Tool Plane Must be set to Top or Off in Entry"
    Can anybody help me to resolve ?
    thank you and excuse my english.
    Dec 2008
    3122
    Generally speaking, when creating a toolpath operation, your WCS and T/C-planes should be the same for a 3-axis machine, unless you have an additional right angled head attachment or multi-axis machine.
    This should be set before starting the operation, if missed, it can also be altered in the operation parameters under "Planes" before passing on to have the toolpaths generated. If you don't set the planes ( according to the machine config ) it will give the error and bomb you out and not keep the operation
    The WCS is how you have the part set in the machine
    T-plane is how the machine will move/rotate that part to execute those paths
    ie.
    WCS=TOP, T-plane=RIGHT cannot work on a machine that has a 4th axis around X-axis (A) as this machine can only get to TOP, FRONT, BACK and BOTTOM
    WCS=TOP, T-plane=TOP cannot correctly work on a machine that has a 4th axis around Y-axis (B) as this machine can only get to FRONT, RIGHT, LEFT and BACK ( it sort of works if only TOP is the only view worked on )
    Vertical and Horizomtal are programmed differently
    verticals----WCS=TOP, T-plane=TOP is the uppermost face presented to the spindle, this allows tha A outputs to be correct
    Horiz- ---WCS=TOP, T-plane=FRONT is the face presented to the spindle, this allows the B outputs to be correct
  1. X2 tool entry cuts edge of pocket
    By paulpounds in forum Mastercam
    Last Post: 03-24-2009, 08:01 PM
  2. mastercam 9, USE ENTRY POINT
    By CApostman in forum Mastercam
    Last Post: 05-20-2008, 01:08 PM
  3. EZset tool presetter - Entry Level
    By jregulski in forum News Announcements
    Last Post: 11-13-2007, 06:52 PM
  4. construction plane and tool plane
    By nervis1 in forum Mastercam
    Last Post: 11-05-2004, 06:53 AM
  5. tool path gen plane
    By july_favre in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-25-2004, 01:18 AM
