587,033 active members*
3,465 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Mini Mill power supply error?
Results 1 to 16 of 16
    Mar 2007
    100
    Hi Guys,
    I have a 2000 Mini Mill that I bought a few years ago and it has been great. I mostly just cut aluminum ( I make prototype molds part time). I have it hooked up as single phase in my garage.
    I just received the following errors:
    292 320V Power supply fault - incoming line voltage is above maximum
    177 overvoltage shut down
    Does anybody know what this could be and how is Haas service (price wise)
    Thanks.
    Jul 2005
    12177
    Did you try to power up again? It could have been a transient over-voltage on the incoming supply.
    Mar 2007
    100
    I reset it last night and ran a program fine, however this morning the same thing but it won't clear. I've tried the power down and reset. Tonight I will check the line voltage and look for any fuses?
    Nov 2007
    1702
    It's summer time. My power company pushes up the line voltage during the summer to get more energy out to their customers during hot parts of the day. I've seen it vary from 110 to 121V per leg, in a single day. I'd take a good look at that line voltage.
    Greg
    Mar 2007
    100
    I should have scrolled up on the alarms because I now see:
    123 spindle drive fault
    Mar 2007
    100
    I should have scrolled up on the alarms because I see:
    123 spindle drive fault - any ideas?
    Nov 2007
    1702
    Does this machine have a "Vector Drive" in the back or is the spindle driven by an amplifier board, same as each axis? It sounds like a bad vector drive (not good news, sorry).
    Greg
    Mar 2007
    100
    yes I think it is Vector drive.
    Nov 2007
    1702
    Well, there is no 'think' in this case; either it's a vector drive machine or it's not. You need to figure out which.
    Vector Drive:
    rectifies high voltage, 325VDC power for all of the axis amplifiers in the machine. It also controls the spindle--it's the spindle drive amplifier. It says "Vector Drive" right on it. It controls all of the spindle's actions (speed, position, braking).
    Non Vector Drive:
    these machines are slightly different. The incoming power goes through a box in the same spot as the Vector Drive. In this case, that box is nothing but a 325VDC power supply. It has a rectifier bridge and some capacitors in it. From there, it takes power over to the axis amplifiers. In a non vector drive machine, they use a high-output amplifier to control the spindle. Other than the increased amperage, it looks just like the X,Y and Z amplifiers.
    How are you with diagnosing electronics and finding & replacing components? There are voltages inside that cabinet that can easily kill you and maybe even light you on fire (no, I'm not kidding). Those voltages are even present after shutting off the power (stored in the capacitors in the power supply). Don't touch anything unless you absolutely know what you're doing.
    Greg
    Mar 2007
    100
    Quote Originally Posted by Donkey Hotey View Post
    Vector Drive:
    Non Vector Drive:
    I answered "I think" because I'm not at the machine and I'm going by memory. Thanks for the warning about high voltage - yes I'm well aware of the dangers. I would like to have an idea as what could be wrong before a Haas technician looks at - analogous to knowing what's wrong before a mechanic fixes your car, so you not wasting money fixing things en route to what is truly wrong. I know my limitations I'm a plastics and mechanical engineer - never liked electrical, however I can trouble shoot. I'm soliciting advise based on the error codes hoping someone has run into the same set.
    The incoming voltage has been constant over a couple of hours so I don't think there is a spike. Is the order of the codes the sequence of failure events?
    Nov 2007
    1702
    Well, I'm not wanting to type out every possible failure because then you're going to have to read through it all, comprehend it and figure out which problem is yours.
    The short version: I think you have a Vector Drive, it's toast, you're about to have your wallet removed through your left nostril and $4000 will be extracted and given to Gene's Nascar team (sorry...that's probably what it is. ).
    The longer version:
    You had two errors: voltage related and spindle drive fault.
    • If you don't have a Vector Drive, it might be the 325VDC power supply. There might be some repairable components inside or you can just get a replacement.
    • If you do have a Vector Drive, there are some failures inside that you might be able to repair on your own. If it's not one of those components, you're looking at $3500-4500 for a replacement Vector Drive.
    Open the cabinet, figure out which type of spindle drive you have and get back to us.
    Edit: one more question--what kind of phase converter are you using, did you measure the voltages inside the Haas cabinet and are all three legs the same? You still need to be absolutely sure that it's not something simple like an incoming power problem, loose ground or other simple failure.
    Greg
    Mar 2007
    100
    Ok, good news I suppose - its not vector drive. I did not check the voltage in the machine yet. I will go that route when I get home from work. I did notice on the 320V power supply the error code is "A" which said incoming AC fault.
    Mar 2007
    100
    Update: I traced the problem to the low voltage power supply (servo amp). It was 6:00 (Massachusetts) last night I called the main office thinking they could ship it out, but they said I have to order through Connecticut, which was closed. The other thing is they said I have to buy the whole assembly PN 93-0962F not just the PCBA that is attached to the back of it for $350.00. The board is made by Skynet PN SNP-9061 (comparable switching power supplys are $45 bucks) so I will call that company to see if I can buy it directly from them. Is there another source for Haas parts or that Skynet part that anybody might know of?
    Nov 2007
    1702
    There's probably a part number on the power supply (along with the manufacturer's name). Google it. It's probably a common, industrial power supply.
    Also try:
    http://www.digikey.com/
    http://www.newark.com/
    Greg
    Oct 2007
    18
    Quote Originally Posted by plastibob View Post
    Try:
    http://skynet.industrialpartner.com/...s/snp-9061.htm
    regards,
    Jim
    Mar 2007
    100
    Haas has integrated the functionality of that board into the low voltage power supply (93-0962F). FYI Skynet will fix the board for $40.00; if they can't they'll send you a new one.
  1. Cincinnati Milacron Acramatic 2100 Power Supply Failure error
    By Wurmwood in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-17-2012, 07:53 PM
  2. Bridgeport mill power supply circuit
    By JohnDG in forum CNC Machine Related Electronics
    Last Post: 06-25-2009, 04:34 PM
  3. Power supply died on Mini Mill
    By PBMW in forum Haas Mills
    Last Post: 03-02-2006, 06:51 PM
  4. Mini-Mill Power supply case
    By hargray2 in forum Benchtop Machines
    Last Post: 01-24-2006, 06:44 PM
  5. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
