586,035 active members*
3,838 visitors online*
Page 1 of 2 12
Results 1 to 20 of 29
    Jul 2008
    116
    Left hand tapping
    I am trying to tap a left hand 7/16-20 tap in kia turn21 with a fanuc oi-TB
    This is what I do for a R.H. tap
    (7/16-20 SPIRAL TAP R.H.)
    G97S200M3
    G0X0Z.2T1010
    M129S200
    G84Z-1.75F.05
    G80M9
    M128
    G28U0W0T1000
    This is what I tried for a L.H. tap and did not work
    G0T1000M8
    (5/16-18 CUT TAP L.H.)
    G97S200M4
    G0X0Z.2T1010
    M129S200
    G74Z-1.5F.05
    G80M9
    M128
    G28U0W0T1000
    Any input would be appreciated
    Kyle
    :withstupi
    You must remember that 99% of my posts are Bullchit!
    Feb 2008
    586
    Why would you change from G84 to G74? All you needed was a change in spindle direction? I' not familiar with the machine, either, or what G74 does differently than G84. Good luck!
    Jul 2007
    25
    When using G74 start your spindle M03 for lefthand taping ,freaks out the boss
    good times!
    May 2009
    104
    You could try G32 instead if you have a TC tap holder.
    Then just reverse spindle directions.
    Works in my older Kiaturn21 as I don't have G84 or G74.
    Jun 2009
    28
    I'm assuming you're doing this in a lathe, and G74 is left hand tapping for a mill. I don't remember the code for left hand tapping in a lathe, but the G32 will work.
    Dec 2004
    5
    LH tapping
    Your feed needs to be .055" (1/pitch) since that is governed by the tap. 18 is a little more coarse then the 7/16-20. Plus you don't explain why it doesn't work.
    Jul 2008
    116
    Begee,
    G74 just seemed logical to me never had to program for a L.H. tap before so I figured I would give it a try. G74 is a milling L.H. tapping cycle
    maz43,
    No TC holder not sure I understand what a TC holder is I think you are talking about a floating head holder.
    jawbreaker38,
    Yes this is on a lathe, I was reading in the fanuc book and it says that I should be using a G84 just change from a M3 to a M4 didn't work
    toolsur,
    were is your math from 1/20=.05, 1/18=.055. I'm not sure I follow what you are trying to get at.
    Here is my problem in more detail
    G0T1000M8 (change turret to station 10)
    (7/16-20 CUT TAP L.H.)
    G97S200M4 (spindle starts in revers)
    G0X0Z.2T1010 (turret positions in front of the part)
    M129S200 (spindle stops )
    G84Z-1.5F.05 (spindle starts in foreword and turret feed Z- and then spindle reverses and turret feed Z+ back to start position)
    G80M9 (cancel G84)
    M128 (cancel M129)
    G28U0W0T1000 (send turret to home position)
    The fact that on the G84 line it doesn't start as a M4 doesn't work for me and I'm not sure how to make it start as a m4
    Thank you
    kyle
    Feb 2008
    267
    this is a long shot but try M129-200
    Jun 2009
    28
    Ok, I guess I'm not getting the M129 command, for rigid tapping I assume? I would've thought that it was M29. I'd go with the G32 method, and I'm sure you will have no problem in rigid mode if done correctly.
    I'd do it like this-
    G00 G18 G99 T202 S500 M04
    X0. Z.1 M08
    G32 E.0556 Z-1. M05 (use E or F on this line and put the M05 on this line)
    G32 Z.1 M03
    G00 Z1. M09
    G28 U0. W0. M05
    M01
    The M05 command will be read last, so it will be performed when the tool has reached it's depth. I neglected to pay attention to the pitch of our thread, but this is just an example anyway.
    Hope this helps.
    Feb 2008
    586
    My 10TF manual mentions G84.1 as left hand tapping function...
    Feb 2008
    267
    My Haas lathe uses G84 Forward Tapping Cycle and G184 Reverse Tapping Cycle. My old Fanuc controlled mill used G84 Forward and G74 Reverse. I would bet that there is a similar Gcode in there to do what you need.
    Good luck and post your findings here as I'm sure they would be usefull down the road.
    Jul 2008
    116
    Proprocess,
    M129-200 resulted in a illegal us of negative sign
    Jawbreaker,
    The G32 worked but snapped the tap in the bottom (bound up chips) of the hole so I tried to run the tap half way in and then to full depth but got a miss match thread. When I ran the the other side witch was 7/16-20 R.H. I had allot higher quality tap available to me, nobody makes a good quality tap in a L.H. that will tap to full depth.
    begee,
    G84.1 resulted in illegal G-code
    The M129,
    This is what I have have found out on the M129. I was not sure what it was for myself until I was looking threw the fanuc book and I found the section 4.22 (parameters of rigid tapping ) in the the parameter manual.
    Parameter #5210 (Rigid tapping mode specification M code)
    [data type] byte
    [valid data rang] 0 to 255
    This parameter sets an m code that specifies the rigid tapping mode.
    To set the M code larger then 255, set it to parameter No.5212
    NOTE:
    1 The M code is judged to be 29 (M29) when "0" is set.
    2 To use an M code whose number is greater than 255 specify the code number with parameter No.5212
    Parameter #5212 (M code specifies a rigid tapping mode)
    [Data type] 2-word
    [Unit of data] Integer
    [Valid data range] 0 to 65535
    The M code that specifies the rigid tapping mode is usually set by parameter 5210. To use an M code whose number is greater then 255 specify the code number with parameter 5212.
    NOTE:
    If the setting of this parameter is 0, the M code specifying the rigid tapping mode is determined by the setting of parameter 5210. Otherwise, it is determined by setting of parameter 5212. The setting of parameter 5212 must always be within the above valid range.
    parameter #5210 is set to 129
    parameter #5212 is set to 0
    So if what I read there and copied to this thread means the same thing to you as it did to me, well that is were the M129 came from as for the M128 to cancel have not found that yet.
    Thank you everybody this is a pain in the @ss
    Kyle (nuts)
    Feb 2008
    267
    G32 (AFAIK) is not going to implement "rigid tapping" mode.
    It will do what you need to do, but you will need an axial compensating holer.
    M4
    G32 Z[to 80% of depth] F[feed at 90-95% of the pitch](this pulls the spring out a little)
    (may need M5 here, dry run first)
    G32 Z[out of the hole] F[100% of the pitch] M3
    G0 XZ(cancel G32)
    this will work all day, but you must have the compensating holder!!!
    I would be very suprised if your control does not have a G code to do this. Have you called your machine dealer or Fanuc?
    Jul 2008
    116
    Yes, that it what the I figured I would need is a holder I'm looking and pricing one now.
    Thank you
    Kyle
    I still want to know the rigid tapping solution, or it will haunt me for life.
    Feb 2008
    267
    Quote Originally Posted by Get lucky View Post
    ...I agree, what did the dealer or Fanuc say?
    Jul 2008
    116
    I don"t know haven't called them yet never really had great history with them. I think I will shot an email off to Kia today asking how they would program it.
    Kyle
    Feb 2009
    64
    Generic tapping cycle for fanuc
    Try something along these lines:
    G97 S(whatever) M04
    G00 X0 Z.5
    G32 Z(DEPTH) F(#) M05
    Z.5 M03
    M05
    This is a very generic method for tapping on fanuc lathes and works RH and LH by just switching M3 and M4 around.
    Jul 2008
    116
    That is what I have now and without a floating holder you get a junk thread and I don't own a floating holder.
    Kyle
    Jul 2008
    116
    I'm glad I'm not the only person with this issue
    Kyle
    http://cnczone.com/forums/showthread.php?t=59775
    May 2009
    104
    TC- tension and compression. If you get a good TC holder with a 1 inch straight
    shank you can use it in your mills too.
Page 1 of 2 12
  1. left hand 3-48?
    By skmetal7 in forum Mechanical Calculations/Engineering Design
    Last Post: 05-05-2009, 07:49 AM
  2. Rigid tapping Left hand
    By DocHod in forum Fanuc
    Last Post: 06-20-2008, 05:54 AM
  3. Why do you use your left hand
    By ImanCarrot in forum MetalWork Discussion
    Last Post: 10-15-2007, 12:14 PM
  4. Left hand cutters
    By DAB_Design in forum MetalWork Discussion
    Last Post: 11-03-2004, 04:23 PM
  5. coverting from Right-hand to left-hand coordinate system
    By eltonr in forum Uncategorised CAM Discussion
    Last Post: 10-15-2004, 02:40 AM
