586,655 active members*
3,403 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > DIY 1/2-10 5 start works pretty good
Results 1 to 7 of 7
    May 2006
    168
    Thanks to Ahren (www.cncrouterparts.com ) who sent me a couple of pieces of 1/2-10 5.
    I milled 4 flutes 3/16" wide and 0.1" deep, then tapered the end.
    The plastic has a .445" hole drilled into it
    May 2006
    168
    Movie
    Here is a short movie file showing the results.
    The tap is around 6" long. I think I will make one around 12" long.
    The process:
    I put it in my cordless drill and went forward then reverse until it broke through, then I did it a couple more times.
    Attached Files Attached Files
    May 2007
    380
    You can reduce or eliminate backlash by the exact diameter of drill bit used for the hole. Worked for me.
    John
    Feb 2004
    1086
    Glad to see it worked out for you! So what now? Are you planning on building a machine? Need any bearing blocks or linear motion components to go with your new drive nut?
    Ahren
    May 2006
    168
    Quote Originally Posted by ahren View Post
    Ahren
    I need to finish the one I am making for dad, http://www.cnczone.com/forums/showthread.php?t=83471
    then I am making him a 2 axis for a small wood lathe, then I am making mine so I have quite awhile before I will start on it.
    I
    Thanks again for the samples...I will have to save some cash to buy some of these acme screws.
    May 2006
    168
    Quote Originally Posted by johnmac View Post
    John
    What size drill did you use?
    I was also thinking about freezing the plastic to make it more rigid.
    May 2007
    380
    I was tapping a hole for 3/4x10 and I don't remember now. My first try was too tight and I used a slightly larger bit. I had extra plastic and did some testing on the scrap.
    John
  1. fanuc 6M -the start key does not works
    By mehrdad in forum Fanuc
    Last Post: 09-13-2007, 09:42 PM
  2. start of a good project
    By mastermoparman in forum Vertical Mill, Lathe Project Log
    Last Post: 06-13-2007, 07:36 PM
  3. IS Bobcad V19 a good program to start
    By Biggermens in forum Uncategorised CAM Discussion
    Last Post: 10-30-2004, 03:46 AM
  4. Single line mode works well, Auto is not soo good??
    By Darc in forum CamSoft Products
    Last Post: 10-26-2004, 09:29 PM
  5. Where is a good place to start?
    By Binow in forum DIY CNC Router Table Machines
    Last Post: 07-16-2004, 08:52 PM
