I am BRAND new to milling, in fact I just got an X3 mill and the 8x14 lathe and just started making my first chips the other day. Everything seems to be going well so far EXCEPT for when I use the side of an endmill to cut a part. I believe this is called facing? I am cutting 6061 aluminum and I have tried both a 3/4" and 1/2' endmills, neither produce any kind of good finish and the machine does not seem to respond to this very well. I have adjusted my feed rate from fairly quick to very, very slow and everything in between with the same bad results. I have also tried climb and conventional cutting, both turning out badly. The 3/4 inch endmill is made by import and is brand new, it worked well for normal milling. The 1/2 inch endmill is a used, but sharp Putnam end mill. What am I doing wrong?!
By the way, in the pic, this was several different passes with different cutters at different depths of cut, but you can see that the quality of cut is very poor in all areas!
