586,121 active members*
3,056 visitors online*
    Apr 2009
    123
    Problems connecting to the controller with Mach3
    Ok connected my computer to the controller the other day (Novakon NM-135 mill), loaded provided profile (Mach3Mill.xml) but no workie.
    1/ Computer is running XP and connects to the controller via LPT1
    2/ Mill is in a running state (no etop etc), table and head are nowhere near the limits
    3/ Mach 3 diagnostics input signals behaving very strange though. I have M1/2/4Homing yellow signals intemittently blinking sometimes not blinking for 20 seconds then would blick 2-4 times then stop blinking. Emergency red LED would blink intermittently as well.
    Clicking Reset button does nothing and does not reset.
    Any suggestions on how to troubleshoot the connection?
    Aug 2004
    2849
    Well, if you don't have any other programs running....I would check your parallel cable...it could be intermittent.....do a pin to pin check.
    Does the Novakon have a breakout board built into it?
    Paul
    Sounds like you have noise on your switch lines.
  1. Connecting bipolar motors to a unipolar controller
    By tommee10533 in forum Controller & Computer Solutions
    Last Post: 05-04-2009, 04:30 PM
  2. Connecting an 8-Pin Stepper so a 6-Pin controller
    By sw_ in forum CNC Machine Related Electronics
    Last Post: 03-10-2008, 09:36 PM
  3. Problems connecting laptop to TNC370
    By iknownothing in forum Bridgeport / Hardinge Mills
    Last Post: 01-24-2008, 01:26 PM
  4. Connecting controller with this motor
    By tom1975 in forum CNC Machine Related Electronics
    Last Post: 09-16-2007, 10:27 PM
  5. Connecting a Controller Board
    By kpkale in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-29-2007, 03:16 PM
