586,119 active members*
3,607 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Any ideas on how to reduce chatter in hard part
Results 1 to 11 of 11
    Mar 2005
    140
    The stock is 4x4x0.125" square tubing. Length is 16" and is being held in two vices with 2" deep jaws. The cut I am making is to remove 15.5"X3.75" from one side. Obviously this is chattering like a ........ due to the walls flexing. Anyone have any tips to make this less painful?
    Jan 2007
    1389
    Fill it with wax
    Dec 2008
    3109
    Yep,
    cut 1/2" off the end- throw the big bit away, and weld a 4" x 1/8" x 15.5" long plate onto the box. LOL
    Any chance of using a long 3" square up the guts and clamp everything to the table, eliminate the vices ??
    or
    Oxy-cut the majority excess, and clamp as above and then machine ??
    after-thought
    what about an internal spacer to allow the vice jaws to actually grip the walls ??
    a couple of bolts with nuts on the end ( bottle jacks ) would work as spacers.
    Jun 2004
    6618
    Cut a block of wood to slip fit in there. It would be semi reusable for several parts, but would become worn after awhile. That would stop the flex and cheap and fast.
    Lee
    mozmozmoz Guest
    If you're not cutting the whole side away you can fill it with something, like they say above. If you can block the ends then (dry, no-salt) sane would be fine, or TIG filler rods if you have enough of them (I've bent tube that way), or a combination of TIG rod and bigger bits.
    But if you're actually just chopping out a chunk of the whole wall, why not make cuts right through? Even milling it with a small cutter would be better than trying to cut away that much face metal. Not sure from your description whether you're trying to cut a window into it, but if you are then just drill a hole near one corner and run round the outside cutting a channel slightly deeper each pass should work and would be a lot stronger right up to the final pass. Small cuts add time but reduce cutting forces (and you suck the big end ) I'd still try for a clamp-down rather than vise fix (like superman says).
    Mar 2005
    140
    Here is an image of what I am talking about.
    I thought about some sort of jack on the inside but the wood is a great solution, especially as I only need to make 4 more right now.
    Mar 2005
    140
    Opps forgot the image.
    Nov 2003
    154
    Put one or two of the small machinist screw jacks underneath it to reduce vibration and crate a little lift/support.
    only an example of the jack I am referring to.
    http://www.use-enco.com/CGI/INSRIT?P...&PARTPG=INSRHI
    Jun 2004
    6618
    Yep. Snug fitting block of wood. Mill in two passes and leave two small tabs on the ends.
    Lee
    Jul 2005
    12177
    Two blocks of wood, wedge shaped, slide them in from opposite ends until they are tight; much easier to get in tight and then out than a single block.
    If you are doing many parts use steel wedges and just make sure you are wedging them between sides that do not have the weld.
    Jun 2004
    6618
    I agree. A pair of wedges would be ideal.
    Lee
  1. Hard Part turning
    By Vaibhav.Shelke in forum Daewoo/Doosan
    Last Post: 10-09-2009, 03:11 AM
  2. How hard would it be to machine this part?
    By kentrob11 in forum MetalWork Discussion
    Last Post: 03-28-2008, 07:06 PM
  3. Any ideas how to scan and trim this part....
    By Normsthename in forum Digitizing and Laser Digitizing
    Last Post: 02-27-2007, 08:35 PM
  4. First hard part, Help!!
    By fastolds in forum GibbsCAM
    Last Post: 06-08-2006, 08:37 PM
  5. How to reduce?
    By ahmed drdeer in forum MetalWork Discussion
    Last Post: 04-12-2005, 09:37 AM
