Will the Gecko 320 servo drive run the servos on a BP mill with the MT30r4-58
servo motor or should I stay with the Bosch drives that came with the mill
I am trying to upgrade the TNC 145 controler and go with a PC based Machine not sure what to do?
Hi I did a Bridgeport with the origional servo motors and the 320s
80 volt power supply works great. search some of the older Bridgort threads for some of my prior posts for more info.
Doug
What break-out board did you use? I have a ton of questions to ask you I am
not sure on what works with what and how to you know. I have about 1300.00 I can spend on getting this mill up and running. I just need to becareful
on how I go. I have talked to John at Pico systems. I like him and the prices
are good. Have you had any dealing with him?
