586,036 active members*
3,552 visitors online*
Results 1 to 7 of 7
    Jul 2009
    15
    SolidCAM - g-code export fail
    Error Message - Line 380, error 41828: System variable 'xc' can not be declared ....
    any ideas what this means? Its my first attempt to export g-code. Its a super simple operation. Its a turning operation.
    If I click OK, i then get this error message:
    Line 713, error 41839: Cannot initialize GPPTool environment
    I can't seem to get past this, has anyone got any ideas?
    It only happens with FANUC0T output ... it exports ok in OKUMAL ??!
    Cheers, C.
    Dec 2007
    12
    Firstly , open FanucOT.gpp file in the notepad. Find XC variable, and change all xc variable name (for example : XC_new).
    You can export g code now
    example :
    @turn_drill
    local string for for1 for2 for3
    for1 = '2/2.0(P)'
    for2 = '2/2.0(P*10)'
    for3 = '5.0(P*1000)'
    local numeric save_feed xc_new
    Jul 2009
    15
    hey yasemintalay, cheers for the info.
    i've done what you suggested, and it's worked. I have no idea what the change means though..... could you explain? I'm a real newbie to all this. What's an xc variable, and why does changing its name in the gpp file help? And what is a gpp file?
    Cheers,
    C.
    May 2010
    Unhappy HELPPPPPP
    line 1195, error 41793: Variable 'xc_newenter' is not defined
    Line 1518, error 41839: Cannot initialize GPPTool enviroment
    What should I put instead of "xc" variable? The xc_new didn´t work properly here Thank you.
    Oct 2007
    499
    Quote Originally Posted by mr chris View Post
    It's easier to start from the end. A GPP file is a post-processor. In other words, it takes the CAM output and puts it into machine code. You can make the post as detailed or as vague as you like; when its vague the programmer has to put all the tool change code, etc in manually whereas when its detailed the code is ready to put straight into the machine with no manual editing.
    The "xc" variable is simply a variable that is used in the post and I am not sure why renaming it helped as the error you had indicates that the variable was not declared with a line thus global numeric xc at the head of the GPP file. What the "xc " variable does can only be understood by studying the GPP file.
    Open up you GPP file and then fire up the GPP help in the SolidWorks / SolidCAM interface so you can study how the GPP functions. Read back through this forum as there are some enthusiatic GPP tweakers here.
    Have fun
    Bob
    May 2010
    generate g-code
    I have solidworks 2010 and solidCAM2008 and I can't generate G-code coz there´s no option for it, i had solidCAM 2007 and it wasn´t any problem. The option "generate" is erased in a gray color, anyone can please help me??????????????
    Oct 2007
    499
    Quote Originally Posted by Uchoa View Post
    That sounds like a demo version of SC2010. Get your dongle codes updated from your your reseller and everything should work as it did.
  1. Is there a way to generate CL code in Solidcam
    By manussim in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-02-2021, 07:02 PM
  2. Lathe g-code output from SolidCAM
    By BSF in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-06-2009, 08:31 PM
  3. Lube Fail
    By CC714 in forum Fanuc
    Last Post: 01-24-2008, 05:39 PM
  4. How to export g-code
    By tazboi in forum Mastercam
    Last Post: 07-06-2006, 09:15 PM
  5. CAM/CAD export to g-code
    By Net-Man in forum Uncategorised CAM Discussion
    Last Post: 07-06-2005, 01:58 AM
