586,119 active members*
3,737 visitors online*
    Jul 2009
    Need Help for Mach 3 Macro+Start by ext.Button
    Hello
    This is my first time here and I hope some clever people could help me.
    Here are my Problems:
    I have an maschine that works togehter with a mori-mill....for this
    1)How could i start mach 3 with externel button-in this case by using a free input of mach 3 like it is possibly for the software PCNC.
    2)I need a macro to turn on of an output by M-comand....in the moment the output is turned on the program had to stop so long till a signal from the end-switches come back
    ..in the maschine driven by mach 3 i use pneumatics with end-switches.....
    For example when i use an output(here M8)to switch a valve the pneumatic cylinder will start to press......
    Hope someone could help...thanks
    Jul 2005
    2415
    You can map hard inputs (ports & pins) to a mach Button by using the OEM Trigger inputs and then define that trigger as a MACH button number in the Hotkeys section. You can get a list of the button numbers in the CODES section of the WIKI at www.Machsupport.com. The RUN button is one of those. You only have 5 inputs on the first parallel port so you may need to use a 2nd parallel port card to get 11 more inputs.
    You can also use a macro and a GetOEMButton() call to do more complex logic (i.e test to see if a function is active by looking at a corresponding LED) and read it through the same OEMTrigger Inputs
    tom Caudle
    www.CandCNC.com
  1. Can spindle start when you hit the Z-axis button?
    By moldcore in forum Milltronics
    Last Post: 04-26-2009, 02:14 PM
  2. Shopmaster start/stop button died
    By sexton in forum Shopmaster/Shoptask
    Last Post: 07-28-2008, 05:12 PM
  3. Physical Button Signal Input Triggering Macro
    By sunmix in forum Mach Software (ArtSoft software)
    Last Post: 08-25-2006, 04:26 AM
  4. Changed screen, now Start button doesn't work.
    By jderou in forum Screen Layouts, Post Processors & Misc
    Last Post: 03-20-2006, 02:57 PM
  5. Cycle Start button
    By kaleem1 in forum Mach Software (ArtSoft software)
    Last Post: 12-24-2005, 09:05 PM
