586,069 active members*
3,484 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Connecting a breakout board to spindle speed control
    Jun 2008
    I have a Chinese xyz-tech cnc machine. It worked well for 6 months but now the dsp handle is dead. I am planning to remove the handle and use a off-the-shelf parallel port interface like the CNC4PC instead.
    The problem is, that I have no idea how their Spindle speed control works. There´s no wiring diagram and no manufacturer label anywhere. I tried to email xyz-tech a couple of times and had no answer. I am asking the cnczone community some educated guesses on what type of spindle control this is and how to connect it to a breakout board...or if there´s any way I can figure this out!
    Your help is going to be very much appreciated!!!
    Attached Thumbnails Attached Thumbnails IMG0242A.jpg   IMG0246A.jpg   IMG0244A.jpg   IMG0241A.jpg
    Jun 2008
    update
    Well, xzy-tech removed the spindle inverter label, but there was a sticker with this "DZB 416" on it.
    I googled it: most of the results came out "Dragon Ball Z" but some good soul posted a pdf manual of a similar (same manufacturer, different model) inverter. The Chinese manufacturer is Fuling Inverter - www.chinafuling.com - but their site is in CHINESE!
    the link with the manual is (the pdf is too large for posting) http://www.cnc-technik-madreiter.at/...r%20manual.pdf
    Well, there are 4 wires coming from handler board to the inverter. "s0, s1, s2 and -vc). Any sugestions????
    Oct 2012
    Manual XYZ-1325 Router
    I found a few queries for diagrams for XYZ Routers here so hope somone can help. I need a wiring and PCB circuit diagram for an XYZ 1325/1350 model Routers. Any help would be appreciated. I did find a manual of sorts at wiki.acemonstertoys.org: http://wiki.acemonstertoys.org/image...Manual1280.pdf which might be of help to some here.
    Regards, KH
    Oct 2012
    PCB in Photo
    Hi wiesberg,
    I have the same PCB as you with limit led's on even when sensor connector '8' is disconnected. Any help appreciated. Regards, KH
  1. Connecting AB Ultra 3000 to Bob Campbell breakout board
    By pvogtcharlotte in forum CNC Machine Related Electronics
    Last Post: 09-05-2012, 06:29 PM
  2. Problem connecting spindle inverter to brakeout board C11G
    By 6bx in forum CNC Machine Related Electronics
    Last Post: 02-23-2011, 10:09 PM
  3. breakout board with spindle speed control
    Last Post: 02-19-2009, 08:35 PM
  4. Replies: 2
    Last Post: 01-24-2008, 11:33 PM
  5. Router Speed Control + Mach3 + Breakout Board
    By Dingo745 in forum CNC Machine Related Electronics
    Last Post: 06-20-2007, 02:58 AM
