Hi
I have a problem with a Colchester 4000 lathe fitted with a Fanuc OTA controll, the cable to the X axis broke, this was easy to fix as extra cable had been left when the machine was built. We just cut off the broken cable and resoldered the plug back on. When the machine was fired up again it was displaying error code 310 (the x axis needs to be zeroed) is this just a simple case of pushing the home button and then the x axis + button. The machine has absolute encoders so no microswitches and ramp cams to zero on, so if there is another proceedure to zero the axis I would be very appreciative if some one could let me know how to do it.
cheers Jim
