586,114 active members*
3,302 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Reference point shifting in a VMC
    Dec 2007
    8
    A vertical machining centre is equipped with a Fanuc 0M-C control. Whenever the machine is switched off and then on, the reference point is shifting in X and Y axes by variable amount (The shifting is not consistent each time the off and on cycle is repeated). The screws of the limit switch banks and the actuators (of X and Y axes) are tightened but there is no change. Please advise on the next course of action
    Visu
    Oct 2008
    106
    I do think you should look into the X & Y deceleration switch, or replace it, it sound like the switch is not repeating
    Ahn Vuong
  1. Fanuc21i-T - Reference point problem
    By Dare in forum Fanuc
    Last Post: 01-22-2009, 11:04 PM
  2. G30(reference point return)
    By Reg wharton in forum Daewoo/Doosan
    Last Post: 06-13-2008, 11:32 AM
  3. Shifting the curved end toward one side
    By randyf1965 in forum SheetCam
    Last Post: 04-27-2006, 12:51 AM
  4. Return through reference point?
    By RBrandes in forum Haas Mills
    Last Post: 12-02-2005, 04:49 PM
  5. Shifting rod
    By venomx999 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-30-2005, 06:07 PM
