586,070 active members*
3,543 visitors online*
Results 1 to 7 of 7
    Mar 2007
    16
    Importing Help?
    Hey guys. I just bought parmaster pro to write programs for my machine. When I try to import a dxf file I get a message that says "Class not Registered". Then if I click OK, it says Partmaster Cad is not installed or never been run on my system. It then tells me to run partmaster cad and then try again and that I may have to reinstall the software. Then if I click ok it opens the dxf but it sure is annoying going through this each time I try to open a dxf. Anybody ever seen this before. I've not tried reinstalling the software yet because I wanted to check here first.
    Feb 2007
    4553
    Post
    Japcas,
    Have you seen the tutorial video's?
    http://www.youtube.com/profile?user=...24/-1Iz-AyLldo
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Mar 2007
    16
    Yes but I'm getting my error when I first click on the file in the folder that I want to import. If I click a second time it will usually open them.
    Feb 2007
    4553
    Question
    What version of Windows are you running?
    Dec 2007
    496
    Are you importing into cad or cam?
    Mar 2007
    16
    I'm running XP Pro and I'm importing into Cam.
    Dec 2007
    496
    I have always imported into cad and then selected my contours to pass over to cam. It seems to be much easier that way. I only use dolphin for the cam.
  1. Importing a JPG into Gibbs
    By Camaro68 in forum GibbsCAM
    Last Post: 08-16-2008, 07:52 PM
  2. 3D to 2D / iges importing
    By teamjnz in forum Uncategorised CAD Discussion
    Last Post: 11-07-2007, 11:20 AM
  3. importing into turbocnc
    By wantsout in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-11-2007, 02:06 AM
  4. importing .dxf
    By ToddAnderson in forum OneCNC
    Last Post: 11-11-2006, 07:34 PM
  5. Importing DXF's into V19 ???
    By tgm in forum BobCad-Cam
    Last Post: 12-09-2003, 03:41 PM
