586,052 active members*
3,990 visitors online*
Results 1 to 7 of 7
    Aug 2007
    793
    Alarm 17 on spindle servo unit
    Hi
    Periodically when I power on the machine I get AL-17 on A06B-6055-H108 spindle unit with A20B-1001-0120 main board.
    Earlier I have been advised possible reasons:
    (1) Meaning
    In the main circuit, the voltage at the DC link is abnormally high.
    A fuse of the AC reactor unit may have blown.
    (2) Cause and troubleshooting
    (a) An input fuse of the AC reactor unit has blown.
    → Replace the fuse.
    (b) Regeneration circuit failure
    → Replace the unit.
    But nothing of this doesn't attend.
    May bad capacitors cause this alarm?
    Oct 2006
    6
    ALM 17
    GUHL your spindle amplifier broken in board side.
    RAM was fault.
    Aug 2007
    793
    Quote Originally Posted by wawan View Post
    ALM 17
    RAM was fault.
    What do you mean "in board side"? Which RAM is mentioned? On spindle?
    May 2009
    106
    There is a chip that stores the spindle parameters on this unit, called NVRAM chip that needs to be either reinitialized and or replaced and the parameters reloaded.
    Aug 2007
    793
    Quote Originally Posted by jdeere4250 View Post
    Ok
    Thanks. Should I read out the contents of the RAM before? Or just insert new IC, reinitialize it and write parameters?
    The procedure of reinitializing is known to me.
    May 2009
    106
    Yes, best way is to write down the contents of the F parameters first, then do the initialization next. Then reload the F parameters. Sometimes you might fint the NVRAM chip just needs to be reseated.
    Aug 2007
    793
    I had parameters written on the cabinet's door and I've reloaded parameters already.
    The time will show the result...
    And thanks for Wawan
  1. Fanuc ac spindle servo unit
    By IDXBaltimore in forum Fanuc
    Last Post: 02-11-2021, 07:34 PM
  2. 1.3 amp alarm fuses blow on my Velocity Control Unit
    By gcpmachine101 in forum Mass finishing equipment/media/strategies
    Last Post: 09-26-2008, 03:52 PM
  3. J/C unit alarm (pallet changer)
    By padobranac in forum Fanuc
    Last Post: 09-25-2008, 08:28 PM
  4. AC Spindle Servo Unit HELP
    By Darkos in forum Fanuc
    Last Post: 10-31-2006, 06:05 PM
  5. Spindle Servo Alarm, Fanuc 3m, Help!
    By MITYDR in forum Fanuc
    Last Post: 07-03-2006, 03:31 PM
