I'm going to get myself 3 steppers for a DIY CNC machine for PCB milling and light alu milling.
I have a choice of the following steppers:
Option 1)
Motor,stepper,hybrid,57mm frame,1.8deg. step angle,2.3V,101Ncm holding torque
Cost/item Brand Frame Size Step Size Holding Torque Num Wires Rated Volts Rated Current Shaft Size Length
R 652.19 ($83.61) RS 57mm 1.8° 1010mNm 4 2.3Vdc 2.8A 6.35mm 51mm
Option 2)
Motor,stepper,hybrid,57mm frame,1.8deg. step angle,2.5V,126Ncm holding torque
R 671.27 ($86.02) RS 57mm 1.8° 1260mNm 4 2.5Vdc 2.8A 6.35mm 56mm
Option 3)
Motor,stepper,hybrid,57mm frame,0.9deg. step angle,2.5V,126Ncm holding torque
R 742.92 ($95.12) RS 57mm 0.9° 1260mNm 4 2.5Vdc 2.8A 6.35mm 56mm
Option 4)
Motor,stepper,hybrid,57mm frame,1.8deg. step angle,3.2V, 189Ncm holding torque
R 982.30 ($125.93) RS 57mm 1.8° 1890mNm 4 3.2Vdc 2.8A 6.35mm 76mm
Option 5)
Motor,stepper,hybrid,57mm frame,0.9deg. step angle,3.2V,189Ncm holding torque
R 984.01 ($126.15) RS 57mm 0.9° 1890mNm 4 3.2Vdc 2.8A 6.35mm 76mm
Which of the above would be the best bet to get? And the difference between 1.8 and 0.9 deg steppers?
