586,108 active members*
3,100 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > 4th Axis Rotary, Brush or Brushless
    Jun 2006
    629
    How can I tell the difference from a brush or brushless Haas Rotary unit?
    A neighbor has one that I could borrow, but I need a brushless to run on my machine, and it is an older model.
    "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
    May 2007
    30
    Look at name plate. example:HRT 210B
    B = brushless!!!
    24221
    If you can take a look at the motor, the brush holders are usually visible to the outside, either 2 or 4 at the rear of the motor.
    Not always applicable, but if it is a square motor body with heat sink ribs, it is DCBL or AC.
    Or even the drive itself could be marked with the type.
    A DC drive has two power conductors to the motor, DCBL/AC has 3.
    Al.
    Albert E.
    May 2007
    30
    you can still run a brushed motor from brushless drive amp. Just need a conversion kit.
    Jul 2005
    12177
    Brush type has a single plug, brushless has two plugs. You can get adaptor boxes to go both ways I think; brush type on a machine with brushless 4th and brushless type on a machine with brush 4th.
    Send me a PM if you do not get sorted out it is possible we have an adapter not currently in use.
  1. Replies: 0
    Last Post: 07-16-2009, 02:50 AM
  2. Axis Motors Brush replacement
    By Delw in forum Fadal
    Last Post: 02-11-2009, 05:35 PM
  3. X-Axis VF-0 Brush Motor
    By lkenney in forum Haas Mills
    Last Post: 11-13-2008, 06:32 AM
  4. Brush or Brushless
    By Nilad in forum Gecko Drives
    Last Post: 09-05-2006, 03:00 PM
  5. PacSci SIGMAX E32 hybred motors... Are they Brush or Brushless?
    By ngr1 in forum Stepper Motors / Drives
    Last Post: 10-15-2005, 07:59 PM
