586,108 active members*
3,174 visitors online*
Results 1 to 5 of 5
    Oct 2020
    Reset part counter
    Greetings, I am looking for some guidance I have a fanuc series Oi-TD machine. Where I need to implement a counter for finished pieces. But this counter I need it to reset at an specific hour. How can I do this using PMC? Or what is the best way to do it?
    Aug 2019
    145
    Re: Reset part counter
    Look at the operators manual under "Parts Count Display, Run Time Display". Depending on what exactly you are tying to accomplish this may suffice.
    You could also create your own counter using macro variables and a sub to increment, reset, or preset it whenever you choose.
    Jun 2021
    25
    I’m not sure there is a parameter that contains the current time of the machine
    For a 0i-TD, parameter 6710-6752 contains integer values of the count of machine parts along with operation time. If you’re able to use those parameters in your G code you might be able to make something work
    Post the ladder file and we can make the modifications
    Oct 2019
    17
    #3012
  1. How to reset the new M30 Counter on the lathe in PP
    By smokediver576 in forum Tormach PathPilot™
    Last Post: 03-12-2020, 11:19 AM
  2. Replies: 1
    Last Post: 06-11-2014, 02:53 AM
  3. Help - Conquest ST-20 Part Counter Reset
    By Wolves in forum Hardinge Lathes
    Last Post: 02-15-2012, 12:42 AM
  4. Part Counter Reset
    By Outlaw6700 in forum Milltronics
    Last Post: 02-27-2010, 12:00 AM
  5. Reset Parts Counter
    By martsto in forum Milltronics
    Last Post: 09-18-2007, 04:59 PM
