586,082 active members*
3,826 visitors online*
Results 1 to 6 of 6
    Apr 2006
    49
    What is typical engraving speed?
    I am building my own laser engraver/cutter. What is the maximum speed (ipm) I should plan for when engraving. I have seen some videos and they appear to move pretty fast. I plan to use a 35W laser initially then upgrade to a more powerful one.
    Currently I am running at 2000ipm with an acceleration of 300.
    See my buildlog here....
    http://www.buildlog.net/cnc_laser/index.html
    Dec 2008
    1258
    You have plenty of speed.
    Well it depends on material, but I typically run at around 10-12 cm/s for engraving (~280IPM) wood or Acrylic at 10W.
    Vector cutting is slower.
    Zax.
    Apr 2006
    49
    Thanks Zax,
    What is the typical stepover to the next pass? I know it probably has a lot to do with focus, material, etc. I am just wondering what a typical value might be.
    Dec 2008
    1258
    You are correct, step over does vary based on material but 0.1mm is a good target. The spot size on my laser is 0.1 to 0.2mm depending on focus.
    Zax.
    Apr 2006
    49
    So if I do my calculations right, it would take 30-40seconds to engrave a 1" x 1" area at 280 ipm and 0.1mm stepover.
    Dec 2008
    1258
    Probably a little longer, when accounting for the over travel and decel/accel at the ends of each line.
    You could go faster, I'd say 2X that speed if needed by increasing the laser power, it all depends how deep you want the result.
    Zax.
  1. Oddity with high speed engraving
    By Roger Hamlett in forum MetalWork Discussion
    Last Post: 02-14-2009, 12:02 PM
  2. LG series engraving speed?
    By jinu117 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-26-2007, 07:30 AM
  3. discusion- Max engraving speed
    By lazerawy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-08-2007, 01:24 PM
  4. Engraving with High Speed Spindle
    By MichaelHenry in forum Tormach Personal CNC Mill
    Last Post: 06-27-2007, 01:25 PM
  5. which speed for steel and bones engraving?
    By jaru-eri in forum Benchtop Machines
    Last Post: 06-20-2006, 01:35 PM
