586,069 active members*
3,613 visitors online*
Thread: Tach kit
Results 1 to 6 of 6
    Sep 2004
    145
    Cool Tach kit
    Hi all,
    Does anyone know about an inexpensive electronic kit (or maybe another way) for a tach that I can install on my mini-lathe and micro-mill. Something using a hall-effect, prox switch or optical, whatever. I just want a digital readout of rpm.
    Thanks in advance
    Mark
    Jun 2003
    1365
    Take a look at http://cnc4pc.com I bought 2 of their kits and they look real good. I had them running in both turbocnc and mach2
    Jon
    Feb 2005
    37
    Not a kit. Ready to go with all the parts. I use this one myself. With a second wheel and sensor it is easy to move to another machine.
    http://www.littlemachineshop.com/pro...ProductID=1684
    Jun 2003
    1365
    oh, I see, all your looking for is a readout? nothing for cnc I assume? The one at cnc4pc is for readout on a cnc.
    Jon
    Dec 2004
    518
    Look here
    Quote Originally Posted by mark c
    Hi all,
    Thanks in advance
    Mark
    Camtronics has an optical tach kit that uses reflective strips. Go here to see what's available, or email Dan Mauch at [email protected]. I believe he is also a member of cnczone. We are talking under $50.00. Good luck.
    Nov 2003
    93
    Smile
    I just posted a file to the turbocnc site that is a circuit of a tach I just built and installed on my lathe..The site is www.dakeng.com Look in files....the file is called tach.bmp..If you want me to send it to you just email me at
    [email protected]..
    Andy
  1. 4-axis unipolar kit
    By itsme in forum Xylotex
    Last Post: 03-03-2005, 12:26 AM
  2. Kit or Already built Balsa/LitePly/Depron CNC cutter?
    By Xnaron in forum DIY CNC Router Table Machines
    Last Post: 11-23-2004, 05:22 AM
  3. CNC Retrofit - Kit verses turn on and go
    By MetDetect in forum Uncategorised MetalWorking Machines
    Last Post: 07-13-2004, 04:06 AM
  4. 4th axis plans or kit
    By seansear in forum DIY CNC Router Table Machines
    Last Post: 04-01-2004, 06:52 PM
  5. Cheap tach
    By Zephrant in forum CNC Machine Related Electronics
    Last Post: 06-05-2003, 08:11 PM
