586,069 active members*
3,410 visitors online*
Results 1 to 7 of 7
    Jul 2009
    5
    Cincinnati milacron arrow 500 to pc
    Hi ,need a little help ,if any one has any experience with linking Cincinnati milacron arrow 500 to a pc (mastercam)i would appreciate it.I`ve had more than 20 years on cnc`s and know mastercam.
    Dec 2007
    159
    machinelink
    I have been using a program called machinelink for years.Download a demo and see if will work for you.
    Jul 2009
    5
    Mastercam is not the problem , i cant seem to get the two computers to talk to each other
    Feb 2008
    586
    gotta play with the communication parameters. I think if the PC is 7 data bits and the Cinci is 8, both with even parity, both with the same baud rate, both with 2 stop bits, it should work. I do know they aren't the same on each machine.,
    Dec 2007
    159
    gazzaa
    Machinelink is a communication program.
    Jul 2009
    5
    Thankyou one and all for the sugestions. along the same lines , Has any one got a copy of "One CNC" or "NC link"?
    Mar 2011
    7
    cnc to pc
    i had the same problem you can download a programme called easy dnc it is on a 30 day trial in this programme you can plug your lead into pc and cnc and scan the port it will ask you to send a programme from the cnc to pc on the cnc screen in the programme screen press transmit programme out will start sending programme on the pc will look garbage to start with leave easy dnc do its thing will after a few seconds programme will match what you have in cnc ports will then be set you can then send programmes in and out with no problems this dnc was so good i bought it after the trial i think it was around £100 for a lifetime hope this helps regards james.
  1. Cincinnati milacron arrow 500
    By shmoo in forum Uncategorised MetalWorking Machines
    Last Post: 12-10-2014, 10:33 PM
  2. cincinnati milacron arrow 750
    By kevmor in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-06-2009, 08:26 PM
  3. Replies: 1
    Last Post: 09-12-2008, 08:42 PM
  4. cincinatti milacron arrow 750
    Last Post: 04-11-2008, 04:10 PM
  5. Cincinnati Milacron Arrow 750 Serial Port
    By kirkmachine in forum DNC Problems and Solutions
    Last Post: 09-21-2007, 03:38 PM
