586,308 active members*
3,385 visitors online*
Thread: Planes?
Results 1 to 6 of 6
    Aug 2007
    95
    Planes?
    Is it possible to create a plane on a curved or domed surface? If so what are the steps?
    A plane is flat. If you wanted a plane on a domed surface, it would only meet at a single point. So you'd need to know the location of that single point, as well as two other points, or a line, or perhaps a parallel plane for reference.
    Perhaps you need to clarify a bit more exactly what you want?
    Does the plane need to be on the curve or dome? Your feature can start on the surface even if the plane is above it?
    Jun 2003
    513
    Yes, you can create a plane tangent to the surface of the OD. Open the plane tool, then click on the OD and select a plane that is defined along the axis of the cylinder. It will create a plane tangent to the intersection of the selected plane and the OD of your part.
    Feb 2009
    2143
    Quote Originally Posted by dpark1 View Post
    No, as mentioned a plane is flat and a dome is 3D. You CAN, however, project a sketch from a flat plan ONTO the curved surface (see attached screenshot). What are you trying to actually do, though? You likely don't need to draw on a curved surface...
    Sep 2005
    1660
    You can also put a plane tanget to a domed face as long as you have a orientating point on the face of the dome. No other geometry is needed as there is only one solution for a plane tangent to a dome at one point.
    Simply sketch a point or project one, onto the dome and then using the insert plane function select the point and the dome surface as well as select the "on surface" button near the bottom of the dialoge panel.
    Voila..
    J
    JerryFlyGuy
    The more I know... the more I realize I don't
    Apr 2006
    822
    Or... you could draw a sketch on an existing plane that will be Normal to the desired plane. This sketch would have to have the end point be Coincident to the Dome surface.
    Create a new plane by selecting the option to create a plane "Normal to Curve"
    Select the end point of the line and the line itself. See attached picture.
    Brian.
Name:	SW Plane Creation.jpg
  1. planes on surfaces?
    By dpark1 in forum Solidworks
    Last Post: 07-25-2009, 06:47 PM
  2. Changing planes
    By CNCMike in forum Mastercam
    Last Post: 04-16-2008, 04:17 PM
  3. changing planes
    By norvil1 in forum BobCad-Cam
    Last Post: 01-04-2008, 04:27 AM
  4. another new SW user with a ?? re: planes
    By weaver in forum Solidworks
    Last Post: 03-07-2007, 05:26 AM
  5. Do like R/C planes???
    By cncadmin in forum Hobby Discussion
    Last Post: 07-30-2006, 12:17 AM
