586,096 active members*
3,510 visitors online*
    Feb 2007
    126
    green light in mdi mode
    Hi all. I've been given a "problem" to figure out by my supervisor.
    I am running a Mori-Seiki SV-50, control FS-15M. There is a light on the top of the machine which shows green while the machine is in cycle. My manager noticed that the green light is sometimes on at other times.
    I experimented with it and found that using MDI mode would cause the green light to come on, and that it would stay on till given an M30, either from a program cycled or in MDI.
    He is adamant that this is a problem which needs to be fixed and I would like to satisfy him. Can anyone help me?
    24221
    It all depends on how the OEM configured the light activation in the ladder.
    It sound like when a command is given by cycle start the light will be on, I am suprised it down not go out in MDI without M30?
    This sounds like a ladder oversight.
    It sounds like you will require the ladder (PMC) program to be changed by someone with ladder programming experience and the necessary programmer.
    Al.
    Albert E.
    Feb 2007
    126
    Thanks for your time Al. I was hoping this could be a parameter change but it doesn't appear so.
    Feb 2009
    6028
    SV50
    That is normal. BTW, there is no F15 control on ANY SV50. 16 or higher.
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. Replies: 3
    Last Post: 06-18-2009, 09:13 PM
  3. Replies: 6
    Last Post: 10-26-2008, 12:16 AM
  4. Spectra light and Light machine owners have ?
    By ZipSnipe in forum Benchtop Machines
    Last Post: 07-19-2008, 03:52 AM
  5. Machine Recommendations Please - Light Duty, Prototyping, Light Production in metal
    By SCG11762 in forum Uncategorised MetalWorking Machines
    Last Post: 08-27-2007, 02:08 PM
