586,075 active members*
4,417 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Data transfer software for Fanuc 18-T
Results 1 to 12 of 12
    Jul 2009
    21
    Hi.
    I have a problem with my lathe that has Fanuc 18-T control. The problem is that I have to have a computer for tranfering programs to lathe's memory and back, and now my computer is broken.. I had a very, very old computer with no graphic operating system, just dos-based software for data transfer and simple editing, and the programs were stored simply as xxxx.min files. I once opened one file with notepad and it only contained the code, nothing else.
    Now that my computer is broken, I have to have some kind of software through which I can do the transfer, can anyone tell me what kind of program should I get, possibly running on a bit newer computer and a graphic OS such as Win XP or older? Or even Linux, though I don't know how to use it. Any free and easy software, I have no idea what should I get or where to find it. It doesn't even need to be a kind of software that has editing state, just one that does the transferring to lathes memory and back.
    Thanks...
    24221
    Free one here for one machine. http://www.cadem.com/dnc/freednc.htm
    Al.
    Albert E.
    Aug 2008
    292
    you might try Hyperterminal which is included with Windows XP.
    May 2009
    181
    Quote Originally Posted by DMF_TomB View Post
    that is correct i use it all the time.. .and its free!
    Jul 2009
    21
    Ok thanks very much, i didn't realize I could use even hyperterminal for that...
    But another problem, does anyone know what kind of com-port connection settings do I have to use for that fanuc control? Baud rate, stop bits etc? I haven't done the earlier computer installation myself so i don't know what should be used. I have a few manuals for that lathe but the connection settings are mentioned nowhere...
    May 2009
    181
    Quote Originally Posted by Pyretta-Blaze View Post
    just do this
    make parameter 12 bit 0=1
    553=11 for 9600 or 10 for 4800
    make ISO =1
    make i/o=1
    and you should be set..
    Jul 2009
    21
    Quote Originally Posted by fanucman View Post
    just do this
    make ISO =1
    make i/o=1
    Could you explain these settings, im not an expert with these things...
    May 2009
    181
    if you go into the parameter setting page...
    you need to set those parameters just like i showed..
    make PWE=1 and do those changes...
    acutally these are for the zero systems... so i fawked up sorry...
    ill post them when i find my book...
    Sep 2008
    16
    dnc
    try dostek dnc.
    Jul 2009
    21
    Any news about the settings yet? I'd appreciate if someone could explain what parameters should i change, and also to what should the connection settings be set to.
    24221
    This is for the Cadem s/w for the 18m.
    Al.
    Attached Files Attached Files
    Albert E.
    Jul 2009
    21
    BTW I got the data transfer thingy working, downloaded cadem free software and with Al's help the settings are now as they should. Also tried hyperterminal and it works also, but its a bit difficult for me to use because the little experience I've got from it comes from years ago at secondary school.
    Thanks Al, you're the man.
  1. Replies: 17
    Last Post: 07-23-2020, 10:30 AM
  2. Portable CNC data transfer Box
    By xyzer in forum DNC Problems and Solutions
    Last Post: 07-21-2011, 06:53 AM
  3. FANUC O-TD data transfer problem
    By flyfishing89 in forum Fanuc
    Last Post: 06-04-2009, 10:44 PM
  4. Replies: 1
    Last Post: 08-28-2008, 01:20 AM
  5. Fanuc 9M data transfer problem
    By YOO in forum Fanuc
    Last Post: 01-18-2007, 03:26 PM
