586,115 active members*
3,340 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > A little advice on an upgrade?!
    Mar 2004
    73
    I've got a 40(x) x 30(y) stepper driven router. I am using dual drive motors on the "X" axis to eliminate racking of the gantry. It runs very well MOST (90%+) of the time. Every once in a while, the X motors will stall during acceleration from a stop if the current reduction has kicked in. I'm currently using Hobby CNC's Pro driver board and their 305 oz-in motors. I also have a CNC4PC board that I'm using to provide step and direction signals for a second "X" motor driver instead of using MAch 3's slaving function. My gantry weighs about 25 pounds, router and all. Will a Gecko improve the reliability of my X axis motors? Which one should I use (knowing I'll be using one for each of the X motors) and what capacity of power supply? I'm inlaying custom cutting boards and if the router screws up in the middle of pocketing the board for the inlay, the board's in the trash!
    Feb 2007
    4553
    Post
    M1911bldr,
    Have you read this thread?
    http://www.cnczone.com/forums/showthread.php?t=49043
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  1. New and in need of some advice... well alot of advice!
    By GoonShoes in forum Bridgeport / Hardinge Mills
    Last Post: 05-30-2007, 01:03 PM
  2. Upgrade Advice
    By dighsx in forum Gecko Drives
    Last Post: 05-19-2006, 01:32 AM
  3. AutoCad Upgrade advice/options..
    By hotponyshoes in forum Autodesk
    Last Post: 03-15-2006, 11:17 PM
  4. Vmc 40 -5 upgrade
    By redman in forum Fadal
    Last Post: 11-19-2005, 02:22 AM
  5. Advice / help? - HobbyCNC upgrade for SpectraLight 0200
    By Sporqster in forum Hobbycnc (Products)
    Last Post: 06-16-2005, 03:55 AM
