586,070 active members*
3,517 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Denford Orac Conversion to MACH3
    Jan 2008
    52
    I just aquired a Denford Orac lathe, and it seems to have a bad controller. I think id rather convert it to full MACH3 control. I have ready most of the threads i could find on other peoples experiance doing this, and they all seem to have used Gecko drives and a breakout board like the ones sold at cnc4pc.com This seems to be an expensive route. I was wondering if the controller sold at www.hobbycnc.com would work in this application.
    I am also quite confused on how to setup the spindle drive motor to work with MACH3. I know i will need a DVM, but i dont know much about them.
    Any help would be great.
    Thanx
    Adam
    Apr 2007
    151
    Adam
    If you want to use the Orac stepper motors they run at 70V dc so your drivers need to match.
    You say the parts are expencive I don't know how much you paid for the Orac but a set of new electronics THAT WORK will set you back 700-800 usd, as long as you paid sensable money to buy the lathe, when you add up to get bottom line, were else can you get a real CNC lathe ( not a conversion) for that price.
    Mike
    Jan 2008
    52
    That is very true, i just looked and that board can only handle 36v
    Jan 2008
    52
    Can you give me a a sugestion on what VFD to use? I know it needs to have an output of 380v and 3 phase, but thats all i know, anyone?
    adam
    Apr 2007
    151
    I used a Mittsubushi VFD the smallest in there range, ebay is a good source or just google for your local motor control dealer.
    Mike
  1. Denford / Mach3 Help
    By JQ_Quint in forum Benchtop Machines
    Last Post: 10-31-2018, 12:29 AM
  2. Denford Orac Conversion to MACH3
    By adbradley in forum Controller & Computer Solutions
    Last Post: 07-29-2009, 06:59 AM
  3. Denford Star Turn4 - Can I use Mach3?
    By JQ_Quint in forum Mini Lathe
    Last Post: 10-29-2008, 02:45 PM
  4. Orac Conversion
    By Maurice in forum Mach Lathe
    Last Post: 06-08-2008, 01:29 AM
