586,121 active members*
3,330 visitors online*
IndustryArena Forum > CAM Software > CamWorks > programming multiple offsets
    Nov 2008
    47
    Is there a way for camworks to program multiple work offsets eg. g54,g55,g56, and so on? What I want it to do is send tool 1 to all offsets before switching to tool 2 and then send tool 2 to all and so on. Right now I just copy and paste the code over and over. Is there an easier way to do this? I am using a Haas VMC
    Mar 2008
    638
    Without using Assembly Mode, you can right click on "NC Manager", "Sort Operations..." and then click "Across Setups" or "By and Across Setups".
    I say, without using Assembly mode simply because I don't use it and don't know if that option is there. I believe it is but don't know for sure.
    Tell us what you find.
  1. Multiple C-axis offsets?
    By bman356 in forum G-Code Programing
    Last Post: 04-03-2009, 10:17 PM
  2. Multiple offsets
    By Tinker Simpleto in forum Haas Mills
    Last Post: 12-05-2008, 02:01 AM
  3. multiple work offsets in MCX
    By bob1112 in forum Mastercam
    Last Post: 10-01-2008, 02:17 PM
  4. Tl-25 multiple offsets for same tool Help
    By mkmk123 in forum Haas Lathes
    Last Post: 11-24-2007, 01:22 AM
  5. Multiple Fixture Offsets
    By Benji in forum EdgeCam
    Last Post: 05-02-2007, 10:28 PM
