586,103 active members*
3,547 visitors online*
Results 1 to 9 of 9
    Sep 2008
    16
    Red face High speed machining
    How to I enable high speed machining function on Fanuc o-md control?
    Jun 2008
    1511
    Check your PM.
    Stevo
    Sep 2007
    371
    It is an option bit, 900's.
    GP.
    Feb 2007
    314
    I'd like to know me too!
    Jun 2008
    1511
    PM sent.
    Stevo
    Jun 2006
    31
    I'd like to high speed machining too,pls. help me
    Feb 2006
    1792
    high speed machining vs normal machining
    How does high speed machining feature helps in machining. I understand, it concerns with machining at high feedrates and low depth of cut, which overall results in higher MRR. Cann't we do this in normal machining mode?
    Mar 2005
    988
    You "can" but it's also (simply stated) a matter of accuracy and accel/decel control. In a standard G64 mode, it has limitations of this at higher speeds (coupled with a lesser value of Look-Ahead). Many machines won't even allow you to hit the extremely high speeds unless the mode is active.
    It's just a part..... cutter still goes round and round....
    Oct 2005
    1237
    many old ones also don't have the high spindle speeds needed either
  1. What is high speed machining
    By Klox in forum Hard / High Speed Machining
    Last Post: 04-11-2014, 05:13 AM
  2. high speed machining ?
    By ssrmr2 in forum OneCNC
    Last Post: 11-18-2008, 03:18 AM
  3. High speed machining
    By cncwhiz in forum Fanuc
    Last Post: 11-13-2008, 07:10 PM
  4. What is high speed machining
    By johnm in forum Hard / High Speed Machining
    Last Post: 12-29-2004, 11:41 AM
  5. Welcome to high speed machining
    By cncadmin in forum Hard / High Speed Machining
    Last Post: 03-30-2003, 04:45 AM
