587,370 active members*
3,596 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Autcad UCS trick
Hybrid View
    Apr 2003
    416
    Autcad UCS trick
    If you use a lot of UCS's try this. (great for 3D work)
    Instead of saving/recalling a UCS, it is easier to insert a text label in the drawing for each UCS.
    While in the UCS you want to save, Use DT (dynamic text) to place a text label anchored at the origin.
    Anytime you want to recall that UCS use a keyboard shortcut to align the ucs with that text entity:
    (DEFUN C:uu () (COMMAND "UCS" "E")) ; Align ucs with entity
    I usually copy the text into any layer that I might use it from.
    An added advantage is that when I copy and insert these layers into a new drawing, the text (and therefore the UCS's) get inserted too.
    Bill
    I use something similar. I assign the keys of the keypad to the different isometric views. 5 = top, 2 = front, 4 = left, 1 = swiso .... Then I can change views with 1 key press.
    (defun C:2 (/ )
    (command "view" "front")
    (princ)
    Mar 2022
    13
    Re: Autcad UCS trick
  1. need a trick
    By KBW in forum Uncategorised CAM Discussion
    Last Post: 05-28-2007, 09:42 AM
  2. 0,0,0, UCS, and Ace
    By JW Peters in forum Autodesk
    Last Post: 04-12-2005, 01:02 AM
  3. Little known trick
    By Turbine in forum GibbsCAM
    Last Post: 07-28-2003, 04:37 PM
