586,096 active members*
3,014 visitors online*
Page 1 of 2 12
Results 1 to 20 of 26
    Jul 2009
    Exclamation morbidelli 504 tria 7500
    I can't load programs into the control via floppy. Can anyone help. There are no alarms.
    Jun 2006
    10
    I have expiriensed the same problem once, the floppy drive was broken. Try whit a new drive.
    Aug 2010
    Need urgent help for a Tria 7500 controller. Back-up batteri is gone dead, so the controller lost all data. Need help for the procedure to reinstall data. Got disk whith all data on (original) but need help step for step.
    Jun 2006
    10
    Morbidelli 504
    Hey SNS.
    I got the procedure for both 503 and 504 whit a Tria 7500 controller.
    Just send your mail address and i send it to you.
    best Stoned.
    Aug 2010
    Hi Stoned
    Thank you.
    My email is [email protected]
    Hope it's works
    best SNS
    Oct 2010
    Quote Originally Posted by stoned View Post
    Hey SNS.
    best Stoned.
    Hi Stoned
    pls send me too. I have a same problem.
    lllhuy
    Jun 2006
    10
    Just send me a valid mail adress, and i post the procedure to you.
    Stoned.
    Oct 2010
    Stoned.
    Hi Stoned
    lllhuy
    Oct 2010
    I Thought I was the Only One
    Stoned
    I would very much appreciate you sending me the proceedures as I to have a dead battery and need to reload.
    e-mail [email protected]
    Thank You
    CADMAN-LV
    Feb 2006
    14
    Hello every one.... is somebody able to help me?
    I have problems with A504K.. when loading the files of the PLC
    when this in the installation process
    it doesn't finish.... and it puts an error..... "Register not connected Y131"
    In other times I had reinstalled those all the parameters
    without any problem....
    Jul 2008
    7
    tria7500
    same problem here, I think you have to know how to boot from the floppy disk
    does anybody have the instructions on reloading the plc, it just says input/output error
    email [email protected]
    Dec 2010
    Hi Stone,
    I have the same problem, can you send me the procedure,
    I have a morbidelli Author 504
    and my email is
    [email protected]
    THANKS!!
    Apr 2011
    I sure could use this info also. I am also looking for someone familiar with this controller
    Thanks Mike
    [email protected]
    Sep 2011
    Hi, can you send me the reloading procedure too if any of you still check these forums.
    I have a morbidelli 504
    Address is [email protected]
    Feb 2012
    Need Help! Tria 7500 Author 503 morbedelli with automatic tool exchange
    Need Help! Tria 7500 Author 503 morbedelli with automatic tool exchange:Can not find the proper start up discs ours seem to not be working ... contacted scm in the states with no luck tried calling UK with no reply yet. Can anyone help ? Thank you !! [email protected]
    Jun 2011
    Morbidelli Author 503 (1995)
    Hi all.
    Is there anyone who can tell me if you can use G code X Y Z generatet from PC then transfered to the CNC by floppy disk?
    example would be nice
    I ask because right now we program directly on the CNC point to point and we use autocad to get the point to points and then punch them in manualy and some of the programs are very very long so it would be good to have a program where you can import the autocad drawing and generate the X Y Z and just copy it to a floppy disk and load it as a SUB program.
    Any ideas is helpful guys.
    Best regards
    Flemming
    Oct 2012
    Plz help when i start to reload the plc and put disk in fdd write {errore triaset.sat 1122h generico error} what what do I do cant reload plc email [email protected]
    Jun 2006
    10
    Hey redline5.
    A generic error on a Tria 7500 can be many things, but the most common is that there is an error an the disk or the disk drive is corrupt.
    If i my memory is right, you might have to leave the write protection open on the disk whit the plc files, when you are reloading them.
    Unfortuanily i dont work whit a Tria 7500 anymore, so i can`t try i out myself.
    Stoned
    Re: morbidelli 504 tria 7500
    Dears,
    I have problems with Morbideli A510. Try to upgrade PLC bud I guest i have not correct parameters. There is parameter invalid Axis 1,15 and Gendata 1,19?
    Any sugestion
    Apr 2012
    Dejan,
    I have some parameters for A510 and if you want, i send to you. [email protected]
Page 1 of 2 12
  1. Tria 7500 for Morbidelli Author 503
    By stoned in forum Controller & Computer Solutions
    Last Post: 03-28-2024, 07:58 PM
  2. Tria 7500
    By num1040 in forum CNC Machining Centers
    Last Post: 11-30-2019, 03:12 PM
  3. Morbidelli Author 503 (1995) Tria 7500
    Last Post: 03-05-2014, 03:42 PM
  4. TRIA 7500 software missing
    By pablogvivo in forum Controller & Computer Solutions
    Last Post: 01-07-2014, 09:45 AM
  5. 'Errore Generico' Morbidelli tria 7500
    By fmorandini in forum Maintenance DIY Discussion
    Last Post: 11-03-2013, 06:48 PM
